Anyone know turbo cam designer
Old Dec 19, 2003 | 12:49 AM
Jammer's Avatar
Default Anyone know turbo cam designer
Superior Cam Design/Grind reccomendations??
Old Dec 19, 2003 | 09:02 PM
TwinSpin's Avatar
ttt ttt
Old Dec 19, 2003 | 09:15 PM
eviltwins's Avatar
www.cammotion.com
that's all you need to know.
Old Dec 20, 2003 | 05:00 AM
Jammer's Avatar
They recommended... 223/218 .576 /.564 116 lcs 112 IC
But they did this without asking many specifics I thought would be necessary to come up w/ a good fit. Another option was 231/226 .591 / .574 115 111
Any thoughts?
Old Dec 20, 2003 | 10:33 AM
frcefed98's Avatar
Call Seth at Cmotorsports. He can pick you a grind and is real specific about what you are running. www.cmotorsports.com
J
Old Dec 20, 2003 | 05:06 PM
RICE ETR's Avatar
Turbo Addict
I second that... call Seth, he'll get you straight.
Old Dec 21, 2003 | 12:06 PM
Noyzee's Avatar
8 second mod
Try talking to Ken or Kevin at east side! They have a good bit of knolage as well as a good cam expert they work with. they helped out picking my cam.
Old Dec 21, 2003 | 01:05 PM
qqwqeqwrqwqtq's Avatar
You don't have the same cam we installed? What did you end up changing it to?
Old Dec 21, 2003 | 06:30 PM
Jammer's Avatar
Brad, Ken has had issues returning my call unfortunately. This goes back two weeks when I was trying to prepare for my Gen 7 install. I have asked Tom at SI to work on a cam for me so we'll see what happens there.
Thanks Guys.
Old Dec 22, 2003 | 09:37 AM
Noyzee's Avatar
8 second mod
I still have the cam you did. But i will be changing it when I put my internals in. It is a close grind to this one, just a bit bigger. It seems to make power, but my new motor should handle a bit more.
Im doing a budget build.
Stock rods,crank. just good pistons and rod bolts. Then clean the block a bit and freshen the heads. Trying to stay cheap but strong enoph to make some good power to go 9's!
We shall see!
Old Dec 22, 2003 | 09:45 AM
KHShapiro's Avatar
i hear GWP (KENNY) is great with Turbo cams
