Best intake mani for boost??
With these Vic Jr intake manifolds - what fuel rails are being used? Can you only use the set that is provided with it? Do they even flow well? - saw them on SummitRacing was just curious
Its easiest to just run the Edlebrock rails. You can get the complete rail kit from Jeg's for $80. But it will not come with AN fittings or hose. So you will have to pick those up as well. Mine cost a total of $210 shipped for all my AN fittings, hose & quick disconnect to install my rails.
I still think the fast intakes are ok options as well for maybe under 20psi boost levels.There are fair amount of cars on here running them now with a few problems reported occasionally.
I have the older fast 90 and will be going to 15 to maybe 20max psi this coming season on it. I may upgrade to the new 92 fast not sure yet.
I did a few extra things ,drilled and tapped my fast for vacuum line and moved my map off of it. And use some rtv between the shells in addition to fast gaskets. Also loctite on the hardware connecting the shells. I am a bit worried about the blow out discs that installed for my nitrous see how that works out. So far have had no troubles at all but have not gone past 8psi.
I wanted a nice streetable powerband since my car is 99% street and also fast is great for direct port nitrous option which am using. Small shots of nitrous can work well with turbos giving instant spool up and supercooling effect. I think if didn't run the fast or direct port would run the ls6 as best bang for the buck and could still use nozzle type spray. The direct port was more for car show and intimidation reasons anyway.
