What's the diff between LG's G5X2 and EPP's Blower cam? Same Dur. & Lift
LG's G5X2 - 232/240 .595''/.609'' 114 Bad *** N/A cam
EPP's Blower cam - 232/240 .595''/.608 115 Bad *** F/I cam
I imagine this one is over my head. Ramp rates?
I've ran the G5X2 naturally aspirated for the last 5k miles and have decided to move to F/I.
Should I keep it? I'm looking for 10-12 psi. 50% pleasure cruising, 40% highway drag and 10% occasional track event.
Honestly, I hate surging, and if it'll still pull like a freight train up top with a smaller cam it's worth it for me to swap. If it'll pull cleanly from 14-1500 rpm without a hickup, I think I'll keep it.
Thanks, Russ
347 BTW
Thanks, Russ
347 BTW
I've even seen a boosted G5X3 that laid down some serious #'s (650 or so at the wheels). I know it's possible, very possible, but i'm worried about the drivability of it.
I'm aware I might as well get a LS6 cam...But hearing a chunky idle, along with a couple of whistling twins out the back of a 911...IMO that's what dreams are made of.
It seems that EPP's blower cam is one of the most popular F/I cams. Turns out it sounds sick and has a serious track record. My cam (X2) is so close in basic profile to EPP's, how much different can it be? I've got a stock Fbody cam in the garage but I would rather hand you my man-hood and change my name to "Russell The Eunuch"
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
But joking aside I appreciate the response.
Your cam is on a 114 lobe sep. Plenty good for boost. The Torquer 2 I mentioned is on a 112 lobe sep. Turbochargers have more wiggle room on what cam will make good power, in my opinion. On a car that is less than a ton and a half, you will have crazy power to weight as it is.
What form of FI are you planning?
If it's a blower, I say run it. One degree narrower LSA won't make a difference worthy of a cam swap. There is a wide range of FI-friendly cam specs and your is well within the range.
If you choose turbo then you should get cam advice from someone who has a similar setup and end goals as you.
Jim
Jim
I wouldn't waste any time with an LS6 cam or anything similar. I've been there and done that. My LG cam made a HUGE difference over it. And the EPP cam is a bit bigger than the one I have.
Go BIG!!!
Go BIG!!!
I'm learning every time I jump on here. 9's are my goal and i'm 2840 lbs...
It seems that EPP's blower cam is one of the most popular F/I cams. Turns out it sounds sick and has a serious track record. My cam (X2) is so close in basic profile to EPP's, how much different can it be? I've got a stock Fbody cam in the garage but I would rather hand you my man-hood and change my name to "Russell The Eunuch"![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
Here Here, I couldnt not agree with you more!!
Deuce turbos.
Jim
Jim
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Woo!
I do not know this to be a FACT, but besides the obvious, the LG cam also most likely has some advance ground into it. +4 is quite common with a lot of cams. I believe the EPP cam has no advance ground in going off the picture I saw of the specs on the end of the cam posted somewhere on this board.
Russ
His original post asked about the LS6 cam too and its been edited.
You do have a donkey dick of a cam!!!
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Thanks, yeah you're right. The G5x2 IS +4. Would that make my power a little to high in the rev range and delay spool a little? I'm new to boost. This is a street car. So If I need to find a 22x/23x 115-116 cam to bring the boost in sooner, i'm changing flywheels asap so it's no problem, the motor will already be out.
Russ
Russ
