Ninetres 10.5 Twins Build
Old Jan 19, 2010 | 02:00 AM
ninetres's Avatar
Default Ninetres 10.5 Twins Build
Oh yes. The time has finally come to start the thread. I race in the West Coast Hot Rod Association Limited 10.5 class (www.NOT-A-SPONSOR.com.org.gov.net). This will be my second year and first complete season. Last year I made a couple races to get my toes wet in actual competitive events and I am ready to win this year lol. I could not have even though about this years upgrades with out picking up a couple GREAT sponsors: Jose @ forcedinductions.com, Eugene @ Gene's Performance, Nate @ All Out Performance and Rick @ Synergy Motorsports. If any of you guys need turbo products definitly call Jose tell him I said he will give you a huge discount :p Here are the cliff noted plans, pics to follow!!!!
The Bulllet (nothing new)
370ci 9.1:1 LQ9 by All Out Performance
Weisco pistons
callies rods
stock crank
coated race bearings
24x/23x 6xx/6xx 114 cam
AFR22 heads
yella terra rockers
victor jr intake (okay this is new this year!)
Custom Gene's Performace Turbo kit
Twin custom 60mm turbonetics units
(2) 45mm Turbosmart WGs
JGS 60mm BOV
custom SS tubular manifolds
3.5" SS downpipes
3.5" Aluminum exhausts back to axle
Custom 2000hp A2W intercooler mounted in cab
Custom 8 gallon water tank
Turbosmart manual boost controller
All hot parts wrapped
Fuel
Custom sumped 9 gallon tank in stock location
dual bosch 044s
dual dedicated -8 feeds
-8 drain
Fuel lab FPR
Fuel lab filters
edelbrock rails
160lb injectors
Drivetrain
Rossler Terminator 3 Powerglide
Art Carr 3600 converter
Aluminum shaft
3.25 gear in spooled 9"
STOCK PCM
Synergy 2-step
Pics will be updated frequently. Please post up any questions and I welcome ALL feedback! Thanks!
*PLEASE DO NOT POST NON-SPONSOR CONTACT INFO!
Old Jan 19, 2010 | 02:06 AM
russian's Avatar
i guess i might as well introduce myself here
Name is Eugene and im building this badass turbo setup for Sean. we're both extremely excited about this build, its going to rock!
Few pics of the car as it sits.
Just ordered up the materials for hot side piping and in the mean time i got cracking on the Custom Fuel cell thats ~9.5 gal capacity.
The sump will have 2 -10 fittings to feed 2 Bosch 044 pumps.
Tomorrow i'll get started on the Water tank for the A/W IC setup.
Old Jan 19, 2010 | 02:07 AM
russian's Avatar
more pics
Tank will be pressure tested to 100psi once its completely welded up.
Old Jan 19, 2010 | 02:13 AM
ninetres's Avatar
Eeeew. You posted pics of my car all torn apart??? lol Guess it will make for good before/after pics!
Old Jan 19, 2010 | 04:49 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
The work so far looks nice. I hope you are taking some weight out of it this year.
Old Jan 19, 2010 | 09:17 AM
ninetres's Avatar
I'm hoping for 3500lbs. Has to be 3400 minimum in the class I run in. The only weight mods left for me are REAL expensive so I might not get to them until next year.
Old Jan 19, 2010 | 10:14 AM
LS1RedZ's Avatar
Should be a fun build!
Old Jan 19, 2010 | 10:30 AM
FANTAZ28's Avatar
Moderator
you are gonna have a hell of a time racing with a manual controller.
Old Jan 19, 2010 | 10:54 AM
ninetres's Avatar
They handicap the Fuuuuck outta the EFI turbo cars in my class. On the contrary though the nitrous cars can not use a controller.
Old Jan 19, 2010 | 11:24 AM
Josh@PremierAutosports's Avatar
How fast do you need to run to be competitive?
Old Jan 19, 2010 | 12:08 PM
Louis's Avatar
You pressure test that tank to 100 PSI, you will blow it up. 1-2 psi tops, even then, itll balloon up and potentially crack.
It just needs a liquid in it to make sure it doesnt leak since in service itll never see pressure.
Old Jan 19, 2010 | 12:23 PM
eviltwin_1987's Avatar
Nice build! Make sure you post up when you take it to sac raceway, I wanna see this thing in action
Old Jan 19, 2010 | 12:33 PM
ninetres's Avatar
8.60ish to be competitive........but I want to win. Last yers best pass was 8.55 at 165 in the heat I believe.
Old Jan 19, 2010 | 12:42 PM
russian's Avatar
you need to change your sig sean!
Old Jan 20, 2010 | 04:32 PM
russian's Avatar
some goodies showed up
Old Jan 20, 2010 | 05:57 PM
MelScrilla's Avatar
looking good, I have been wanting to see what to small turbos could do when compared to a single 88 or something similar.
Old Jan 20, 2010 | 07:18 PM
russian's Avatar
TONS of room in stock location for a cell.
Old Jan 21, 2010 | 12:58 AM
russian's Avatar
fuel cell is complete
Old Jan 21, 2010 | 03:19 AM
Nacho SS's Avatar
This should be good...great looking build so far.
Old Jan 21, 2010 | 05:15 PM
c5blkvette's Avatar
Originally Posted by Louis
You pressure test that tank to 100 PSI, you will blow it up. 1-2 psi tops, even then, itll balloon up and potentially crack. It just needs a liquid in it to make sure it doesnt leak since in service itll never see pressure.
LOL... 100psi. I think people forget that psi is pounds force / square inch.
BTW: if you do want to test a vessel to 100psi, make sure it is pressurised with water and not air. Otherwise, kiss your family goodbye before you do it...
