Oil in the intake - help!!
Old Jan 20, 2010 | 09:37 AM
boosted4life's Avatar
Default Oil in the intake - help!!
I have a vortech g-trim on an ls1 and I have oil pooled in the intake before the supercharger. Am I getting blow by or do the seals need to be replaced in the blower? Thanks..
Old Jan 20, 2010 | 10:23 AM
Boosted One's Avatar
If it's pre blower, are you sure it's not oil from a K&N or similar filter that has been cleaned and re-oiled. Is it red?
Old Jan 20, 2010 | 10:32 AM
No its not from the K&N. It is dark, not red.
Old Jan 20, 2010 | 12:57 PM
XtremeDime's Avatar
Whats your PCV system look like?
Old Jan 20, 2010 | 01:15 PM
AKMac's Avatar
I bet it's PCV related. My NA 402 is doing the same thing right now.
Apparently it's pretty common once you start feeding the engine more air.
Old Jan 20, 2010 | 01:52 PM
Cool, ill re-route it and see what happens.
It feeds in before the MAF and blower.
Old Jan 20, 2010 | 01:54 PM
XtremeDime's Avatar
Run a catch can at all?
Old Jan 20, 2010 | 02:06 PM
98Z28CobraKiller's Avatar
Restricted User
If there is no oil in the charge pipe, you are probably just building some crank case pressure that is pushing oil around the rocker bolts that go into the intake runners in the heads. You can try pulling the rockers off, blow out the holes with shop air, put a little rtv on the threads and tighten it back up.
Old Jan 20, 2010 | 03:31 PM
Thanks guys, and there isn't a catch can.
Old Jan 20, 2010 | 04:05 PM
SKINNY69's Avatar
I agree with the majority. Seems pcv related. Add a catch can and route the vacuum line after the MAF. The last thing you want is oil building up on the maf and skewing the readings.
Old Jan 20, 2010 | 05:25 PM
mike13's Avatar
Oil on the MAF will cause a noticable loss of horsepower, us STS rear mount guys have experienced this. Once you get it all sorted out make sure to clean the tubes and MAF.
Old Jan 20, 2010 | 08:19 PM
Thanks guys.. ill make sure to get it cleaned up and re-route the pcv.
