pyramid rings with L92 heads???
Old Jan 24, 2010 | 10:48 PM
Reject's Avatar
Dosnt a engine shop sell a setup allready made with the grooves and eeryrhing?
Old Jan 25, 2010 | 06:28 AM
cjg454ss's Avatar
Originally Posted by bottlefed370
Those are awsome numbers but what kind of heads allowed you to do so? I read more horror stories about l92s than good when it comes to higher boost, but i just think i might keep them and go either route of ringing to test them out as i dont believe anyone has done it just yet?
will know in about 2 months
Old Jan 25, 2010 | 11:37 AM
slangegger's Avatar
Originally Posted by elias_799
i do not think it will work for the dodge diesel guys, the dodge trucks use a Cummings motor and the head is cast iron. i am pretty sure you need an aluminum head for the pyramid ring to dig in to.
The Cummins guys use what they call 'fire rings'. They are a mild steel, and they are not triangular in shape.
http://www.puredieselpower.com/Tech/...ringoring.html
Does anyone know if these pyramid rings are stainless or mild steel?
P.S. There is no 'G' in Cummins
Old Jan 25, 2010 | 09:04 PM
elias_799's Avatar
my mistake, i do not know how to spell
100psi is allot of pressure threw that motor, i guess using fire rings makes a big difference
Old Apr 9, 2010 | 12:41 PM
DaGreightOne's Avatar
Updates, updates, updates.... please
Old Apr 9, 2010 | 12:50 PM
cjg454ss's Avatar
im waiting on my bs3 to get here. then its ready to run
Old Sep 5, 2010 | 10:29 PM
cjg454ss's Avatar
well the car is running, i have it conservatively tuned, 15* timing, 18psi on E85, it seems to be good so far. air fuel is 11.0
Old Sep 6, 2010 | 08:26 AM
87silverbullet's Avatar
You are doing good for 18lbs on a set of l92's. veee8 on here started to lift the l92 heads just north of 15lbs on his previous motor due to the thin deck casting.
Old Sep 6, 2010 | 08:36 AM
cjg454ss's Avatar
87silverbullet- i was trying to search for some of his old threads. I dont know if he was oringed and i thought he had an issue with the ls7 gastets. i forgot to add im running the ls9 head gaskets with the larger head studs cut torqued to 110ftlbs.
Old Sep 6, 2010 | 09:42 AM
Just pm him. He is a cool guy to talk to. I bought the sheetmetal intake from him that he had on the l92 headed motor. It looks like I might be selling it soon though, going a different route.
I heard the larger head studs don't make a difference because you are still dealing with a thin deck casting. I might go with the Mast motorsports heads since they are thicker casting and I can still use the sheetmetal intake. I keep looking at the PI heads though.
Old Sep 6, 2010 | 10:46 AM
wilson34's Avatar
Aren't PI and Mast partners now?
Old Sep 6, 2010 | 11:21 AM
  #32
cjg454ss's Avatar
i checked the car this morning after hitting 19psi a bunch of times last night. seemed like i lost a half quart of coolant. im not sure if it was pushing water or air in the coolant system, i had drained and flushed the system yesterday, so it could of had an air bubble.
Old Sep 6, 2010 | 02:38 PM
  #33
Yes they are. When I posted I was looking at those two heads at least a year ago. I just saw this thread in the engine section a couple of days ago.
https://ls1tech.com/forums/generatio...der-heads.html
