Boost wont go over 6psi ?
Old Jan 21, 2010 | 02:26 AM
Mohammed's Avatar
Default Boost wont go over 6psi ?
A friend got '00 GT stang with p1sc , car has about 480rwhp , suddenly the boost lowered to 6psi, it was about 9psi . checked everything and didn't figure out what the problem is !!
what could be the problem ??
Old Jan 21, 2010 | 02:41 AM
1dirtyZ's Avatar
check the hoses to see if something came loose , also check for belt slip or something that might restrict the filter.
Old Jan 21, 2010 | 02:44 AM
Mohammed's Avatar
Do you mean there is air leak somewhere ?
Old Jan 21, 2010 | 06:56 AM
cjmatt's Avatar
yes, when a supercharger is spun, it puts out a certain amount of air no matter what, the only way your boost would drop is if the air is either leaking out a hole, or the belt is slipping and not letting it spin fast enough. How many rib pully do you have on the supercharger
Old Jan 21, 2010 | 08:48 AM
Mohammed's Avatar
Sorry , but I didn't get ur question
Old Jan 21, 2010 | 09:06 AM
KS91Z28's Avatar
'96-'04 GT Mustangs are 6-rib drive, but they can be converted to 8-rib.
Check the bypass valve. The vacuum line may have come undone, or the diaphram may have developed a hole in it.
Old Jan 21, 2010 | 10:23 AM
cjmatt's Avatar
the supercharger pulley and belt will have a certain amount of grooves on it. the more grooves, the harder it is to slide the belt.
a 6 groove pulley is most likely sliding, put on a new belt and see what happens
Old Jan 24, 2010 | 06:41 AM
EPP's Avatar
EPP
Look for belt dust on the blower, it will be black in color. Belt dust is an indication the blower belt is slipping. A new blower belt will generally appear to be too small at first, and may be hard to install. After a half an hour to an hour of use, the new belt will stretch and may need to be retightened. The first hour of use should be limited to part throttle use, to allow the belt to break in. Bob
Old Jan 24, 2010 | 09:53 AM
Mohammed's Avatar
I'll do that on the day
When we opened the hose in the front of the blower we found some oil on the edges , i think the filter caused that ... is that ok ?
