The setup....
Old Dec 21, 2003 | 10:42 PM
1F8TL02WS6's Avatar
Default The setup....
I have been trollin around here for a lonnnnnnnnnnnnng time trying to piece together what i want for my setup. Well I figured I would go ahead and post what is the best way to do this.
This is what I wanna do...
Single Turbo T-76
Now I need to know what is the best way to go about this motor. I have thought about the Lunati 8.5:1 CR kit, with all that stuff. With this setup and with the power im gonna be puttin down is this even worht it?
or should I go with a cutom ground cam, 6.0L heads, what kind of pistons? stuff like that. what am I exactly gonna need to make this work and make this motor bullit proof to hold alot of boost somewhere around 12-15 on pump gas. and take it even higher when racing, or maybe even higher then that on the race gas.
Thanks alot guys this has been getting my mind bent backwards trying to figure all this out.
Seeya!
Old Dec 22, 2003 | 10:56 AM
Whistler's Avatar
Sawzall and Welder Mod
What exactly are you asking? Sounds like you know what you need. If you want to do the internals of the engine, 6 litre heads and an FI system all at once, set at least $11K aside first. If your engine is running now you could buy a turbo kit and keep the boost low until you can do everything else.
Old Dec 22, 2003 | 12:15 PM
CHRISPY's Avatar
I would do good rods, forged pistons (9:1) and stock crank in a stock cleaned up block
big headstuds, mainstuds and good gaskets. fairly mild cam, good springs/lifters. Heads flowing in the 300cfm/228cfm range I/E.
That should be good to over 700RWHP easily with the right tune and fuel system on race gas.
Chris
Old Dec 23, 2003 | 12:51 AM
1F8TL02WS6's Avatar
chris (whistler) I was just asking to confirm anything else to make sure im heading in the right direction and what is the best way to do this application.
chris (are 360) thanks alot dude, I will look into all of this hopefully I will have something together mid summer time.
thanks alot guys, any more input would be awesome!
Old Dec 23, 2003 | 07:13 AM
Whistler's Avatar
You said "the power I'm going to be putting down" ... What kind of power do you want to put down? High dyno #s are cool for bragging rights, but require the rest of the car be up to par in terms of safety equipment, drivetrain, and fuel system.
Old Dec 24, 2003 | 12:29 AM
1F8TL02WS6's Avatar
The power im shooting for is about what chris are 360 said, somewhere around 700rwhp or more...
As of right now im getting all the parts together for my motor and then comes the fuel setup along with all the guages. What would be a good fuel setup to do now that we are on this topic. A walbro fuel pump?
as for drivetrain Right now I have the stock 4L60E tranny that I know is going to exspload. I was thinking of switching to a fully built T-56, 9'' rear with 3.73 gears.
I do not want a TH400 with a stall or nothing cause I want the car to be fully streeable without any type of stall oy anything. The car will be running at the drag strip with a cage and everything but I want the car to be just like it is now. not turning into a drag car with a big stall.
thanks alot man.
Old Dec 24, 2003 | 03:10 AM
z98's Avatar
z98
Just having a decent converter does not mean its a drag only car! Some cars can be MORE streetable with a loose stall. And when you're talking about 700 RWHP, you'd want a decent stall to keep from smoking the tires every time you take off. If you are set on using a single turbo, you probably don't want 3.73 gears. 3.42 would probably suit you better in the 1/4.
And you can have an auto built to handle that power (TH400, 200R4, 4l80, or 4l60), and all said and done it'd probably be cheaper than a built T56 plus the cost of swapping it in.
Edit: Oh yeah go to www.quartermileperformance.com and look at the single turbo kit on the firebird. With a lower compression ratio, it could be in the 700 hp range.
Old Dec 24, 2003 | 03:05 PM
1F8TL02WS6's Avatar
z98 - thanks alot man, where can I find more info on the trannys you listed?
where and who can build my tranny up the way I would want it. I REALLY want to keep this tranny I have right now, but I havent really reasearched it a whole lot yet, if you can get me some info on these I would really apprciate it. I tried lookin in the transmisison forum but I didnt have much look on there.
thanks.
Old Dec 24, 2003 | 04:30 PM
z98's Avatar
z98
Check the automatic transmission forum, they know their stuff.
Old Dec 24, 2003 | 04:41 PM
Whistler's Avatar
Any 4L60E or 200R4 you put behind a heavy car with 700RWHP and at least that much torque is going to scatter. Does anybody know if a 4L80 will fit an F body trans tunnel?
For a fuel system you can skip the kiddie pumps and go right to a Weldon -15 pump. That will run continuous on the street without the need for a stepdown box and will be the last pump you'll likely need.
Old Dec 24, 2003 | 07:30 PM
1F8TL02WS6's Avatar
ight thanks whistler, and z98.
Im going to continue into looking in on these thanks alot for your alls input so far.
any advice on what size injectors 42#ers or go even bigger with that pump?
thanks.
Old Dec 25, 2003 | 01:22 AM
Whistler's Avatar
You'll need at least 72#s for +700RWHP
Old Dec 25, 2003 | 12:15 PM
1F8TL02WS6's Avatar
ight thanks alot man for all ur help I think you all have gotten me steerin the right directions, im sure i will have ALOT more questions where these came from here in a lil bit. thanks alot guys!
Old Dec 25, 2003 | 12:22 PM
BIGBOS's Avatar
How much is the weldon -15 pump?
Old Dec 25, 2003 | 06:05 PM
Whistler's Avatar
A 2015 should cost around $600
Old Dec 25, 2003 | 06:08 PM
BIGBOS's Avatar
Is that an external pump?
Old Dec 25, 2003 | 10:56 PM
Whistler's Avatar
Most definately.
Old Dec 26, 2003 | 01:22 AM
Rob Raymer's Avatar
Extreme Automatics 4L60E or 2004R (Cincinnati, Ohio...email me if you need a price quote), Neil Chance or Yank converter, 95lb injectors, FAST System or Gen7, (a 3rd possibility is LS1Edit with an impedance converter box for the 95#'ers), 3.42 gears MAX (maybe even 3.23's depending on tire size), Weldon 2015 pump with billet rails, -10 feed line, -6 return, and a 1:1 regulator.
That should get you started anyway. 650-700rwhp would be pretty easy with that combo.
Happy Holidays!
Old Dec 26, 2003 | 01:32 PM
1F8TL02WS6's Avatar
Happy Holidays!
thanks alot rob, that helped out alot man
I will keep in touch with you via email if I have more questions.
happy Holidays to you aswell
thanks
