speedinc tu3 turbo cam?
anybody running the tu3 turbo cam from speedinc? got any sounds clips? lookin for a cam for my 370ci kinda a small turbo cam from what ive been seeing other people using on 370ci
specs are...
240 240 .588 .588 112
specs are...
Weird cam specs for turbo. Would usually expect to see like 232/240/580 /580/115 to maybe 117 type of thing.
I think if swap out my current cam will try similar one to the above, maybe go 232/240/600/600/117. I don't want more than 600 lift ,turbos are hard on springs and don't like changing out springs too often. I don't like lope and don't like low end surging or cams that are big pains to tune to get to run nice.
Current cam meets my needs pretty good but did use 1.8 rockers to get lift to around 590 range. My duration is pretty tame especially for a 408 engine. Bigger displacements of course can use bigger cams.
Here are my current cam specs with 1.7 rockers.
Lingenfelter GT7 208/230 .554/.546 –121CL
Usually you see normal split duration cams for FI with usually lsa above 114. Sometimes you see reverse splits and rarely do you see the lower lsas. What really would be nice is to see some mag articles with different cams and no other changes to see what effects the various ideas have. It is generally agreed though to keep the lift down so that it is easier for the springs to control things since as said boost makes it harder on the springs.
Also pure power output from a cam might be secondary over things like lope or no lope,low speed surging or no surge,etc. Some guys want a super lopey cam. Some guys can tolerate more surge and other big cam driveability issues and powerband can also sometimes take precedence over peak power numbers.
i'm putting a s88 turbo looking for 800+ at the wheels. using a 6 speed (for now) my old motor loped like crazy and i love that. with this cam will it sound more stock? would that tu3 cam be a real good cam for me? or should i got to custom grind?
The TU2 is: 236 236 .587 .587 112.5
http://www.speedinc.com/catagory.cfm...in%20/%20Heads
so with the lsa being 112 would it not be a good turbo cam?
whats a good place to get a turbo cam? to make crazy power but yet still lope like crazy? or is that not possible with a turbo cam?
