Procharger Pulley install?
Old Jan 26, 2010 | 05:30 PM
MstgKillr's Avatar
Default Procharger Pulley install?
I am installing a new pulley on a D1SC. Do you use locktight and what do you torque it to?
Old Jan 26, 2010 | 07:02 PM
I_Need_Land's Avatar
i impacted the nut/bolt off, then impacted it on carefully.
Old Jan 26, 2010 | 10:15 PM
blue00ZZleeper's Avatar
Yes use loctite, and I went PFT but not to tight
Old Jan 26, 2010 | 11:04 PM
jashell1562's Avatar
262 Loctite and 60 lb-ft for the SC,D,F series blower, per the pulley replacement procedure card. its 40 ft-lb for the p series.
Old Jan 26, 2010 | 11:40 PM
ss.slp.ls1's Avatar
How do you lock the pulley to torque the bolt?
Old Jan 26, 2010 | 11:42 PM
9silverbird8's Avatar
i use a strap wrench.....
Old Jan 27, 2010 | 12:38 AM
i tried with a strap wrench but it wouldnt hold the 3.4" pulley past 20 lbs or so , so i went at it lightly with the impact. no problems so far and its been on and off a few times for various things.
Old Jan 27, 2010 | 01:10 AM
Wicked_C5's Avatar
I guess I need to start thinking about that.
Old Jan 27, 2010 | 02:12 AM
uphigh07's Avatar
i would try a strap wrench also and maybe another buddie to hold it while you torque on it
Old Jan 27, 2010 | 08:54 AM
is the head unit on or off the car? If its on and the pulley is full seated i would put the belt on it and tension the belt. then you can put a wrench on the crank pulley and let the belt tension hold the pulley. I am running an 8 rib and this method works on mine. If its off the car take and old belt and wrap it around the pully and grab the belt where it comes together with a pair of vice grips. belt has to be very tight for this to work though. This is a home made type of strap wrench but it gives you the most surface grip on the pulley.
Old Jan 27, 2010 | 09:07 AM
AFASTYZFR1's Avatar
I use impact, works perfect. Just be careful
