Which is the best meth injection system
Old Jan 31, 2010 | 02:57 AM
nasty_ss's Avatar
Default Which is the best meth injection system
I've been searching the forum and i've found bits of info, but i'm really looking for info from actual owners. i've got a single turbo 99SS stock bottom stock heads and cam. its a small 60-1 turbo and i'm currently running about 8psi. i doubt it'd be a problem to run more but just in case i'd like to run meth. i'd like to see 13-15psi. i'm keen on the snow performance kit with the gm maf pickup built in. aem also has a good kit with their new pumps that constant flow but user controlled safety feature. i'd like a system that would automatically retard any tuned timing and decrease boost automatically if empty fluid or system/pump failure.
Old Jan 31, 2010 | 06:26 AM
Jontall's Avatar
Alkycontrol's support is hard to beat.
Old Jan 31, 2010 | 08:01 AM
AFASTYZFR1's Avatar
Alkycontrol hands down. GREAT customer service! I have had over 50 gallons of meth through mine with no problems. I have heard of multiple snow pumps failing.
Old Jan 31, 2010 | 08:04 AM
whiteboycntdnce's Avatar
+1 ... Alkycontrol has done me right!
Old Jan 31, 2010 | 08:56 AM
spaz1's Avatar
I am using the snow gm maf kit and it hasn't given me any problems at all. It's nice with the maf kit you can start the meth spraying before the boost kicks in. This way you don't have to wait for the 1psi of boost before it start to spray.
Old Jan 31, 2010 | 09:01 AM
AFASTYZFR1's Avatar
Why do you need to spray meth before boost kicks in? haha I don't even want my meth to start spraying until 3psi
Old Jan 31, 2010 | 10:51 AM
spaz1's Avatar
I am not running 2 bar yet. I can run more timing n/a and in boost with it working this way.
Old Jan 31, 2010 | 11:54 AM
MUSTANGBRKR02's Avatar
Alkycontrol is the way to go.
Old Jan 31, 2010 | 12:50 PM
MIGHTYMOUSE's Avatar
my least favorite FI thread rears it's ugly head again.
Old Jan 31, 2010 | 02:16 PM
ninetres's Avatar
Another +1 for alkyconrol here. Julio provides quite possibly the best customer support from all of the vendors I deal with. That goes a long way in my book.
Oh yea, his meth kit kicks *** too :p
Old Jan 31, 2010 | 02:35 PM
bad6as's Avatar
i like the look of ais new comp trunk mount kit, how do they stack up
Old Jan 31, 2010 | 04:50 PM
koji777's Avatar
I've got the snow kit, stg 3. beautiful, simple.
Old Jan 31, 2010 | 05:00 PM
Frans96SS's Avatar
We use AIS on all the cars we install it on. We have installed every kit and AIS is the easiest to isntall and the best kit available IMO
Old Jan 31, 2010 | 06:46 PM
speedracer5532's Avatar
No question Alkycontrol.
Old Feb 1, 2010 | 01:43 AM
nasty_ss's Avatar
i'm seeing that snow performance offers a wastegate solenoid for their safe injection system that will automatically cut boost when the system runs out of fluid. do any of the other systems offer anything like this or would i at least be able to use snow's wastegate solenoid on another kit?
Old Feb 1, 2010 | 02:08 AM
ninetres's Avatar
Other systems assume you are smart enough to keep meth in your tank. You one of those guys who runs out of gas often or something?
Old Feb 1, 2010 | 02:58 AM
Packy's Avatar
+1 for Alky Control kit again
Old Feb 1, 2010 | 04:42 AM
itsslow98's Avatar
Alkycontrol no doubt, i dont think it needs to be said 50 more times.
Old Feb 1, 2010 | 08:45 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
+1 more for alkycontrol. Ive had no problems with mine, and its adjustable to the moon and has all the bells and whistles..
Old Feb 1, 2010 | 03:25 PM
dschmittie1's Avatar
+ 1 for AlkyControl
To the OP If the system is set up and the car is tuned right for the METH the car will see the raised IAT's if the METH pump fails and should pull timing. That is if it is set up properly. also the Alky control does come with a low level indicator so that helps.
On a side note I noticed you said 13-15psi on STOCK bottum end. Good luck with that I hope you are saving up for a Forged motor.
