can you run long tubes headers on a rear lt1 turbo?
The long tubes have more volume, there for you would loose air pressure to spool the turbo. You will actually lose low end power by switching to LT's. And not see any help from them in the top end. Stock manifolds work great, they are thick which keeps more heat in. Leave it the way it is it's the best you can do.
