Someone help me with supercharger cam?
Actually if you have aluminum heads on it already, they are pretty good, as are the iron heads...it is mainly the intake that kills off top end power. The factory intake is junk over 4500rpm.
Or would could get this for $360:
Some other options here:
http://www.summitracing.com/search/?...manifold&dds=1
Jim
Jim
After a while you'll need a new blower and then let the game$$$ begin
Jim
So if you have a billet impeller you have a p600b. They still will be "strait" blades which is called radial. Not until the D1 or D1SC did they every become curved blades, or what they call Helical cut.
Their were very very few P600's made that were not billet. So more then likley you have a P600B. But if you have the serial number, you can always call ProCharger and ask.
the reason i ask is im considering a 3rd gen for my next project and was thinking about just putting in a 5.3 or 6.0 but that was before i knew these TPI motors were capable of this kind of power...
If you get a third gen, definatly plan on getting a 9 in or 12 bolt rear, i already stripped 4 teeth off my pinion gear.. I have not been able to get a 12 or 9 in yet but plan on it.
