procharger VS. turbo?????
I WANT TO HEAR BOTH SIDES OF THE STORY...TURBO AND PROCHARGER GUYS CHIME IN!!!!!!!!
Prochargers have a linear boost curve
i.e.
2000 rpm - 2psi
3000 rpm 4 psi
4000 rpm 6 psi
5000 rpm 8 psi
6000 rpm 10 psi
Turbo's have an "exponential" boost curve
i.e.
2000 rpm - 2
3000 rpm - 4 psi
4000 rpm - 10 psi
5000 rpm - 10
6000 rpm 10psi
i think it just depends on what the person wants from the car to be honest.
Somedays I wish I had gone supercharged but all the knowledge Ive gained, through all the busted knuckles and throwing of tools, with a turbo make it totally worth it. Not to mention, I have 7 months of winter here so if I had a blower I wouldve been done....back in September lol
There are some kits out and several super kits. Ati, vortech to name two super kits.
Turbo kits you have tti, sts, and smaller companies on the board. APS supposedly stopped making f body kits but not 100% sure on that.
Lots of guys can piece together a turbo setup from ebay parts, fabbing things,etc.
Which is superior? Not easy answer. I like all forms of FI, supers,turbos,centrifugals, roots type and twin screw, nitrous..all have their pros and cons ,all work and all are fun.
As said above you get pretty different powerbands and area under the curves from the various power adders.
I have personally been in sts lt1 and sts ls1, ati lt1 and ati ls1,paxton lt1, some nitrous cars,my tt 99 of course and owned a big block chevy with big roots blower in past.
I also own several turbo talons.
I plan on adding an ati procharger to my 96z vert at some point in time almost bought used kit last year.
You can read all about the technical stuff about all the setups but in real life the differences are not as great.
Still overall if have to choose power adder tend to lean to turbos. Can be bit more extensive on install and bit more complex but tend to favor the area under the curve, the ability to control power quickly by playing with boost controller and to be able to ramp in my boost by various methods..rpm,time,etc. I like the sound of turbos and blow offs. I like how the power can come in pretty low on the rpm band and how it can hold the boost from say 3000 to redline.
but the upside is that a turbocharger does not use much engine power to turn maybe 3 present due to a restriction in the exhaust
a centrifugal or a roots type blower will use allot more engine power to turn, i was talking to a guy that had a 1000whp vette and he said that his blower is eating about 250hp
so a turbo set up will make more power on the same psi because it is more efficient, but most likely cost you more and it will have some lag
both have their upsides and downsides, you just have to know what you want
Sorry, I always relate things to women, but it is true. I like the low end torque of a roost blower, but hate the parasitic drag.
I like the ease of installation related to the weekend assembled Procharger, but once it was done I always wanted more to do.
Nitrous was cool, but filling the tanks got old.
Turbos…. Ya! I like the torque curve, I like the feel, I like the sound, I like to tinker with them, and to most they are mysterious Voodoo. My kind of girl!
Some changes have been made lately, but the procharger stuff is still a bit behind, and still a bit high in price.
I have yet to lose to a procharge/vortec car on the street with my crappy little v6 turbo.
https://ls1tech.com/forums/forced-in...rger-guys.html
I vote Take on a challenge and go turbo I don't think you will be disapointed. Just my .02 Turbos are found on millions of factory vehicles,cars, trucks,semis. I have seen them go 100,000 plus miles on my talons.
Of course there are possiblites of buying knock offs or poorly assembled turbos but genuine mits or garett are usually highly reliable.
I will agree procharger seems to be easier install since you don't need oil feed or oil return ,water lines,etc.
Still once a turbo kit or super kit is installed its installed. So if it takes longer to install not a huge deal unless you are paying some shop big money to do it.
And while some turbo kits do require a lot of mucking on the car and might have you lose your air or move around other things like battery, alternator ...not all kits require this.
