Magnacharger noise
I don't mind the open throttle howl, if that's normal, but the low speed and idle noise concerns me. I sure don't want anything coming apart and getting sucked into my engine. For those of you with Magnachargers, are these normal sounds?
"It is hard to gauge the sound without not being physically there. If it is a whine noise or a "whoooo" noise then that might be a normal sound. The supercharger creates a vortex which normally makes a whine noise which is very common on all superchargers.
Now if the noise is more of a grinding noise OR if you are hearing a loud high pitch sound then there might be something else wrong. Normally when it is an issue like this the noise gets worst over time. So weekly you will hear the noise increase."
Not much help and why I hope someone here can give me a better evaluation based on personal experience. I'm certainly not going to drive it until it "gets worst over time".
Magna Charger, Inc.
1990 Knoll Drive
Ventura, CA 93003
(805) 642-8833 - Phone
(805) 677-4897 - Fax
Hours: M-F 8:30AM-5:00PM (PST)
Something doesn't sound quite rite. I've never had as much noise as you are describing out of any of my three Magnuson blowers. Did you buy a used MP112? What size pulley do you have on the snout? Front drive? If you can get ahold of a mechanic's stethascope, you might be able to determine from where the noise is originating.
"If the "gear or bearing noise" is at very low idle up to around 1,000 RPM, then that might be the common gear noise that all superchargers make. To me I consider it a grinding noise, similar to the noise that grinding coffee beans sounds like. This grinding noise normally will eliminate as you increase the throttle and that is when the supercharger whine noise will come into play. In all honestly to me it almost sounds like you are explaining the common gear noise it makes at idle.
On a side note too, the supercharger rotors are covered in a Teflon coating, which normally requires a break in time. The Teflon coating acts like a sealing agent which over times fills in the gaps and provides a smooth finish to help absorb sound. So it is also very common that during the break in time the Teflon coating will fill in the gaps to help soften some sounds."
That makes me a little more comfortable. I guess I'll drive it a few more days and see if the noise changes.
