methanol injection
Old Feb 19, 2010 | 04:45 PM
GMouldy's Avatar
Default methanol injection
What is it exactly and how does it work? the camaro i bought has it on it. but i'm currently deployed and have never even laid eyes on the car. so i was just wondering i some could break it down for me.
Thanks
Old Feb 19, 2010 | 05:16 PM
JAX04's Avatar
well, methanol does a couple things, its serves as a buffer to raise octane levels and lower iats. Some people even use it for added fueling. But the main purpose is to lower iat (reduces chance for preignition) and adds octane. also reducing chance of preignition.
It is sprayed into the intake like nitrous is, through a nozzel. Thus drastically reducing IATs and increasing octane level. You may see some people using a mix of water and meth. but i would venture to say most just spray pure methanol hope to have helped you.
Old Feb 19, 2010 | 10:06 PM
jomomma's Avatar
hopefully you have the alkycontrol kit!
Old Feb 19, 2010 | 10:42 PM
blue00ZZleeper's Avatar
My IAT's went from 80 something to high 30 degree temps with methanol. You can add timing and make more power a little safer. Like said earlier, it raises your octane rating helping to keep knock retard/pinging down. A very good add to any FI car or even high comp N/A setups. I believe with 91 octane (usual on pump here) its around 108/109 (pure meth)
Old Feb 19, 2010 | 11:20 PM
tomz28's Avatar
everyone makes more power with it but you LOL
i made 50 more wheel hp with the meths help and some retuning. good stuff boosted cars love it
Old Feb 19, 2010 | 11:50 PM
candlelit's Avatar
meth is one of the best mods out there if you ask me. at first I didn't have it in my budget, now it's like number four on my top priorities.
Old Feb 25, 2010 | 01:26 PM
GMouldy's Avatar
Cool thanks for the info guys i guess i should have explained everything that was done to my car first.
Stock block, bored and sleeved
Diamond Turbo pistons (9:1 compression)
Eagle rods
Stock crank
LS6 Cam
LS6 Valvesprings
Lucas 42.5 lb injectors
Racetronix 255lph in-tank fuel pump
STS rear-mount turbo kit (bought at Texas Rear Turbos) w/Garrett T-60
STS dual-stage boost controller
STS methanol injection kit (boost/methanol switch mounted in ash tray)
TCI Super Street Fighter 3500 RPM lockout stall converter
TCI large transmission cooler
TCII4L60E transmission rebuilt w/stoutest possible parts
Like i said i have no idea what meth injection is. But how is it activated? after a certain level of boost? and where the hell would a guy get methanol i heard of some people using windshield washer fluid sounded like BS to me. but i was just wondering.
Sorry for the n00b questions, i've been outta the car game for a long time, since probably 2003, then motocross took my life over, and now just getting back into it.
Old Feb 25, 2010 | 07:39 PM
You can use windshield washer fluid concentrate. My kit is currently set up to kick on a 2psi of boost. You can run it off of any 5v reference as well. (maf or map or even tps I believe)
