Twin Turbo Silverado Build
Old Mar 28, 2010 | 08:49 PM
1_bad94Camaro's Avatar
here is what I got done today. Removing the 5.3L.
Old Mar 28, 2010 | 09:08 PM
IT_SS's Avatar
Originally Posted by 1_bad94Camaro
57's im wanting a fast spool.
nice, I know what you mean, that why I'll be running .58 AR on my twins 66's
Old Mar 28, 2010 | 09:22 PM
I know i'll be going bigger once I get a 408 built. I was thinking twin 70's or something similar.
Old Mar 28, 2010 | 10:37 PM
chevybowtie's Avatar
Holy ****! That 5.3 has seen better days.
Old Mar 28, 2010 | 10:57 PM
I have to agree with you there. it has 273,xxx miles on it and it spent 99% of its life in the oil field.
Old Apr 3, 2010 | 09:39 PM
ok. I have a question about my injectors. My 5.3 has a weird plug and I got FAST 60lb injectors that have what appears to be the ev6 plug. where can I find adaptors to make my FAST injectors work?
Old Apr 4, 2010 | 04:35 PM
bump.
Old Apr 4, 2010 | 06:25 PM
Here is what I got done today.
Old Apr 4, 2010 | 09:38 PM
Sandmann120's Avatar
I like the old Vette in the backround.....
Old Apr 4, 2010 | 09:41 PM
Thank you. its my dads 79. he is in the process of restoring it.
Old Apr 4, 2010 | 09:45 PM
Flaco's Avatar
^^^ About the injector harness, your just gonna have to cut the connector ends and get the ones u need and soder them there...
Old Apr 4, 2010 | 09:47 PM
  #32
thank you sir. any recomendations on where to get them?
Big fan of your truck sir.
Old Apr 5, 2010 | 11:48 PM
  #33
Flaco's Avatar
^^^^^^local junk yard and thanks
Old Apr 6, 2010 | 12:38 PM
  #34
Thanks again Flaco
Old Apr 6, 2010 | 01:53 PM
  #35
gnx7's Avatar
where did you get the intercooler? What kind of HP is it rated for? Cost?
Should be a fun project.
Old Apr 7, 2010 | 12:49 PM
  #36
I got the intercooler from GodSpeedproject.com its rated to 800HP. I got it for about 380 shipped to my shop.
Old Apr 7, 2010 | 12:57 PM
  #37
tomz28's Avatar
I called Jegs and told them i was looking for some file fit plasma rings. they told me they had file fit plasma rings and gave me the part number so i looked them up with them on the phone and i told them they were .030 over size and they told me yes they were but they could be filed down to fit my application. I already filed one piston. the thing that is kicking my *** is the crinkled ring for oiling. it fits really tight.
you are going to junk this build by doing this.
Old Apr 7, 2010 | 01:32 PM
  #38
by doing what? I ended up using the stock crinkle ring and file fit the .030 rings to fit. I was lucky enough to get them all in the cylinders with out breaking any rings.
I take critisism very well. I will say I'm new to the LS world so any help I can get is appreciated.
Old Apr 8, 2010 | 04:01 AM
  #39
tomz28's Avatar
just dont want too see something go wrong for you.
ive had some luck with a few stock bottom ends making good power but the smallest thing could kill it IE: rings that are not the right size .
should of keep the stock rings in it. or found some .010 over rings something not so muuch bigger. did you think about the heat and boost on theses rings? they are going to expand and if they were tight going in wait when they are hot with 12psi on them
Old Apr 8, 2010 | 11:52 AM
  #40
I completely understand that. I file fit everything to specs from the chiltons book. The .030 over crinkle rings I threw in the tool box, I used the stock ones. The other rings went in like they were stock sized rings.
