Procharger belt part number??
ok so i have been tring to cross the belt # from epp website for my setup all day witht he napa we deal with and i have had no luck....my setup is the 7.65 crank and the 4.25 blower pulley any help would be appreciated thanks
http://www.exoticperformanceplus.com...html?item=1041
LS1 F-BODY 8 RIB BELT / PULLEY MATRIX
Matrix for 7.65" crank pulley DC017A-008
ATI Dampner #917242
CRANK PULLEY BLOWER PULLEY BELT
DC017A-008 DP340I-08D DB392I-008
DC017A-008 DP355I-08D DB392I-008
DC017A-008 DP370I-08D DB400I-008
DC017A-008 DP385I-08D DB400I-008
DC017A-008 DP390I-08D DB400I-008
DC017A-008 DP400I-08D DB400I-008
DC017A-008 DP413I-08D DB408I-008
DC017A-008 DP425I-08D DB408I-008
DC017A-008 DP438I-08D DB415I-008
DC017A-008 DP450I-08D DB415I-008
DC017A-008 DP463I-08D DB415I-008
DC017A-008 DP475I-08D DB415I-008
DC017A-008 DP500I-08D DB415I-008
DC017A-008 DP525I-08D DB427I-008
Replacement Idler: DC004A-082 2.7" idler with bearing
Idler shaft: DM008A-003
Blower pulley spacer PDW01C-100 .100" D series impeller shim
Install notes
Remove the driver's upper and the lower stand to bracket mounting bolts
and loosen the passenger upper bolt to allow bracket to be pivoted enough
for the belt to be installed over the lower standoff. Hang the belt on the
standoff and install and tighten all stand to bracket bolts.
Some belts will be easier to install if you pivot the supercharger in the
bracket using the lower mounting bolt only. Install the belt over the crank
pulley and then finish installing the blower mounting bolts. The anti-sway
bar may need to be lowered to facillitate installation of some of the
mounting bolts.
The ProCharger crank pulley should be installed on the ATI dampner in the
following manner: remove the 3 5/16" FerryCap bolts on the ATI dampner
retaining the A/C pulley. Rotate the A/C pulley so the 3/8"-16 holes line up
with the 3/8"-16 holes of the dampner. Install the 3) 4" long 3/8"-16 all
threaded stainless bolts with lock and thick washers in the corresponding
holes through the ProCharger crankpulley, ATI dampner and A/C pulley
making sure to hold the A/C pulley tight against the dampner during
installation. Anti-seize should be used on these bolts. This installation
process is necessary as ATI recently changed the configuration of the FBody
dampner which removed the dedicated drive bolt holes.
Take this one as an example.
The DB408I-008 means it is 40.8 in length and the -008 means it is an 8 rib wide belt. Bob
ATI Dampner #917242
Install notes
mounting bolts.
