bettor or worse vacume source's?
thanks
found this on another site...
"The wastegate cares about pressure. You can get a pressure reading from any of the sections you mentioned. If you put the source before the throttle body, the wastegate won't see any vacuum, if you put it after the throttle body, it will see vacuum. Having sit in vacuum might put extra "wear" on the mechanism so I would recomment putting the source on the cold pipe, after the intercooler, and before the throttle body.
The tubing/hose run won't be a big deal if it's a little longer since so little air volume exists in that tube. Putting it on the cold side of the intercooler on an end tank is also fine but I'd stick to the intake piping just before the TB"
If someone could correct me, Ill gladly hook my WG to the PCV port on my TB.
