KY-Turbo Inc. T4 A/C Header Setup
Losing the A/C and running 6.0L manifolds starts at $7500.
Both require a BMR Turbo K-member. Both are one off buids built to order.
I have several Twin setups out on the road.
Is it the same install pretty much, as far as how tough it'll be to install it?
The T6 setup is priced at $7200-7600 and is based around the Garrett GT series turbos. 76mm-91mm. Yes it will keep the A/C. The install is almost identical except the use of a BMR Turbo K-member is a must at this point as it comes with a standard 4" DP. With the T6 setup you are gonna have to stand the radiator up and notch the core support. eigther that or run a small dual pass radiator setup mounted under the core support.
Here is the beginning of a GT91 Setup, and it will work with a gravity oil drain. No scavenge pumps needed.
I have an LSX iron thats in a crate so I haven't done a thing to it yet. I can do whatever I want to with it.
Being you have an LSX block I would do a 9.5:1 408ci setup with some bolt heads in the 245cc range. Crank the boost up to 20+ lbs and 1100+ rwhp should be easy. It would make for a nasty street car. With A/C...
