AES Racing Engines FI Shortblock, longblock sale
I know we're new here, so I will give you guys some background, we're Automotive Engine Specialties located in Elk Grove IL, the company was founded in 2002, between our staff of machinists we have over 30 years of engine building and racing experience.
AES's Tony Schroeder is Engine Builder for Orlando world street finals class winner, World Ford Challenge, and Pro 5.0 Champion Tony Gillig who ran 400ci SBF with F2 Procharger in his Mustang. Amongst many other forced induction cars.
We're very familiar with the machine work and building concepts for forced induction.
AES 370ci FI shortblock: $3399
6.0 Iron Engine block
6.0 LS Crankshaft
Eagle H beam rods 4340 forging - ARP 8740 bolts
Wiseco Pistons, -11cc or 25cc dish, includes coated skirts Wiseco GFX nitrided steel top ring, napier 2nd ring.
Clevite bearings, durabond cam bearings
All parts are thoroughly cleaned before assembly
Crankshaft balanced and polished
Line honed main journal
Resurfaced cylinder deck
Torque plate honed bores
Assembled in our clean, dedicated, engine assembly room.
AES 408 FI shortblock: $3899
Callies Compstar crankshaft 4.000" stroke
Callies Compstar H beam connecting rods
Wiseco pistons -15cc -20cc or -32cc dish
Wiseco GFX piston rings
Upgrades are available
For pricing on any engine or part you don't see listed here email me fraser@aesracing.net or call us 847 956 1244
Thanks!
Fraser
Tony Gillig - AES powered F2 procharged mustang
6.0 LS Crankshaft
- ARP Main and head studs
- Piston Coating
- Custom pistons
- Pin upgrades
- Upgraded crankshafts by Callies
- LS3 Aluminum Block upgrade
- Block O-Ringing is available
- Main Cap Dowels also available
- Billet main caps and installation
- Special pricing on all gasket kits, valve train and cylinder
Thanks!
Fraser
![](https://ls1tech.com/forums/attachments/forced-induction/222294d1269023285-aes-racing-engines-fi-shortblock-longblock-sale-tony_gillig1.jpg)
We have block and crankshaft cores here
I think alot of shops expected cores to be certain price, took orders, then tried to hunt down non existent cores.
Fraser
I think it was more a result of mis management and not charging enough money. We've seen it time and time again.. someone tries to sell an engine cheaper than they should and it bites their ***.
You get what you pay for in the performance world. A person who is worth anything does not give away free labor and quality engines are not dirt cheap. Just the way it is.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
We do machine work on TJ Zizzo's top fuel engines.
They're local to us, those engines are different animal. For a weekend they will take 6-8 blocks, try to use a new block for every hit. Top fuel block is $7500 IIRC so they bring them over to us line hone the used blocks, new saddles, new sleeves, or weld up the block if a rod went through it. The sleeves can't be repaired, new sleeves come from AJPE honed. They're gear drive so you have to be carefull the block isn't line honed too far. They pretty much run those things till the crank can't spin anymore.
We also have an '82 VW rabbit diesel engine in shop for overhaul, we see both extremes.
