Minor Updates on the 106MM SS
David
We are using the AEM set-up. Has a lot flexibility. The shop is an AEM distributor so I got a great deal. Boost controller is the AEM-1000.
This set up is brand-new. Using a lot of the same engine parts, tranny and rear-end. Everything else has changed. It will be a 370ci .. new pistons, but the stock 6.0 crank. The heads (225 AFR's) have been completely gone through, with new springs. There is a lot of stuff I really need to do with the engine and tranny but money is major problem. I have a T-400, but would love to go with either a 210 or glide. The rest of the car is very solid.
For those that have not seen my SS before, the FQuick link has more details on the car.
Thanks
David
A few quick questions, was any prep done on the crank to get it ready, what rods are you using, and are you running a double o ring?
225lb low impedance injectors -- added an AEM injector control box. I understand that the newest AEM will run either low or high, but what I have works good enough for now.
Forgot my camera at the shop..will get pictures up on Friday
David
Big Bird, Nope not E85 -- E98
David
no way would I want to push that crank to the capability of that 106mm
Im always hesitant to go with forged cranks because the factory iron ones are way more forgiving when it comes to punishment. forged ones tend to not like car accidents and i would hate to have one, then find out my $10k motor is toast because the crank snapped when some jerk-off rearended me. but if david pushes it past 1300 and it lasts for a while, i think ill be alright
Im going to be building a 370 soon and was thinking about a forged crank.... but nowhere near your power. I may just keep the stock crank now instead. That one piece is the only thing Im back and forth on.
