TEA 220cc 'Turbo Heads'
Old Mar 30, 2010 | 08:00 PM
trans2000am's Avatar
Default TEA 220cc 'Turbo Heads'
has anybody got any info on these heads? they are priced pretty well. how do they compare to say a afr ?
this is from speedinc website
TEA takes Trick Flow 220 cast cylinder head to new levels by adding 1.450" diameter high rate hydraulic roller dual springs for best valve control under boost, titanium retainers, CNC machined combustion chambers. Intake and Exhaust ports are hand ported. Stainless steel valves with option for special alloy exhaust valve. Thicker .600" deck for best clamping.
These heads are designed to be used with engines sizes 364-418ci.
thanks guys
Old Mar 31, 2010 | 06:26 AM
Fireball's Avatar
they are pretty good midrange setup...best (IMO) would be a PI head
if you plan on pushing hard...get the upgraded (inconel) exhaust valve option.
Old Mar 31, 2010 | 11:14 AM
MelScrilla's Avatar
looks interesting for the budget minded people like me.
Old Mar 31, 2010 | 09:32 PM
who is PI? sorry never heard of them, ya was gonna get the upgrade valves, how hard can i push these heads per say?
thanks
Old Apr 1, 2010 | 01:18 AM
MelScrilla's Avatar
PI is Performance Inductions. Cary (a member here) took over ET Performance and improved on their head design and now almost all the top dog LS guys run his heads. It seems like it used to be All Pro but now PI is the top dog LS head. The only downside is that with the monster performance come a formidable price tag. Even though in the whole cost vs performance ratio the cost is well worth it because from what I've seen they work great.
MelScrilla's Avatar
Oh Yeah Cary also make the baddest single plane intake for the LS if your looking to get the best.
Old Apr 1, 2010 | 06:36 AM
Fireball's Avatar
Cary didn't take over ET...he just bought rights to the design.
I believe the ohio boys are still running the All Pros...but most of the eastern guys are running PI and/or ETP. My new setup will have "vintage" ETP 265s
Old Apr 1, 2010 | 06:38 AM
Fireball's Avatar
thanks
Just a swag would be ~1400-1500 fwhp.
Old Apr 1, 2010 | 04:28 PM
MelScrilla's Avatar
1400 is probably more than my motor will ever see so I think these heads may be the ticket.
Old Apr 1, 2010 | 06:33 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
They sound interesting and the price is decent depending on what springs are in them. I was going to do something really similar as I already have a set of AFR8000, 1.550 diameter springs, open the chambers, and sell the dual springs they come with.
Old Apr 1, 2010 | 07:41 PM
Chris05ssTruck's Avatar
TEA TFS>AFR for sure.
Old Apr 1, 2010 | 08:34 PM
looks like i might be giving the trick flows a try, need to do a kmember also so i can save a little bit of money going with the trickflows
