760rwhp 777rwtq
Old Jan 6, 2004 | 03:28 PM
  #41
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Thanks Wes now go wrench on HermaphroditeZ and put a blower on it.
Old Jan 6, 2004 | 08:32 PM
  #42
qqwqeqwrqwqtq's Avatar
Thanks everyone
Earl H- Compression ratio is 9.2-1 Tests were done on a mix of 110 and 93 (about 70 percent 110). The car runs 11psi and 93 octane all the time however.
Playdough- It is the original LT1 block, with Diamond splayed 4 bolt caps, eagle crank, rods, and Diamond pistons.
PSJ- The cam change was done to raise peak HP rpm. It used to peak at 5,400. Now it peaks at 5,850. It also carries the power further. With the original 214/222 cam, horsepower had fallen of to 600rwhp by 6,200. With the current cam, it is still at 700rwhp @6,200.
I think a 3.23 gear would be perfect with a 17in tire, but it seems 12 bolt gears jump from 3.08 to 3.42, nothing in between.
mongse- I havn't dynoed the car with an open downpipe with the current combination. I probably won't because I don't have any plans on running a cutout. (I like quiet)
I'm not really sure what to make of SS00Blue's post. (as in what context or meaning).
Old Jan 6, 2004 | 09:26 PM
  #43
LS1 BU's Avatar
That thing is making some sick power.
I'm sure we will find some unsuspecting people to race in chicagoland.
Old Jan 6, 2004 | 09:56 PM
  #44
rodent's Avatar
Wow! Great numbers!
Old Jan 7, 2004 | 12:19 AM
  #45
pugs's Avatar
First of all, congrats to Jim. I think you need a tire sponsor for the burnout championships
PSJ needs to get a hold of Vizards book so he can do all his cam math for himself
Old Jan 7, 2004 | 02:04 PM
  #46
LS1Tech Co-Founder
Oh so the new cam pushed up the peak and extended it very nice.
