PT88 turbo Z71 street truck Goes 9.65, 143MPH on boost only! Vid!!
It's still boost only,
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Old setup was with Trick hot pipes, 2 1/2 log, 3 1/2 down pipe and a TC76 BB tubro, 60lbs/hr injectors single fuel pump, 93 Pump gas and E85 mix, 1 meth nozzle and i think about 15-16 lbs of boost.
New setup was with bigger KB Racing hot pipes, 3" log and 4" down pipe, Pt88 turbo, second fuel pump with own line from tank to fuel bridge, 2 more Meth nozzles, 93 pump and 114 race gas mix and 20psi of boost 19* of timing.
I think the cam specs are custom Isky 215/215 .566/.566 on a 114lsa
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Hope fully when he has more time he will add more details, but I think that's most of it.
9 Second Truck Club
Thanks bddy, glad you like it![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
That car was really impressive! I noticed a couple times they cleaned the gravel off the starting line for you. I really wanted to check it out but I didn't get the chance as well. What did you end up running?
I take it you have never been to sac before? yea they just reground the surface and then prepped the crap out of it. the first 60 feet anyway. That was the BEST I have ever seen sac prepped on a TNT and if you walked the starting line it was very good. I was the first car out and went 1.31 and then go our best of 1.29 in an all motor car. But either way thats about the best prep you will get at sac and compared to last year it is 100x better.
Anyways, Awesome truck, I wanted to come talk to you guys about it but just never got time, I was driving the black firebird some of the day and the helping out on the red 4th gen as well.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Yea we know everyone pretty well out there, so I guess we get a couple special treatments which is always nice.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
