Highest RWHP w/Stock Engine and Boost?
Boost has a way of magnifying that problem.
) 575 to 392, which is a 168tq drop!!Any guesses on what I'll get with some 918's in there?
- Dug
or should i not assume the intake valve is the problem area and look at exhaust pressure instead of boost?
So what you're telling me is that barring any other problems, I'm gonna be right up there with you for stock engine
BTW, what was your torque on stock springs?
- Dug
What was your car dynoing when you ran the 11.59 @ 119?
The car had dynoed 533/567 on 10psi, the 11.59 @ 119 was same configuration but only 8.5psi. I tried 10 once that day and it kept blitzing the ET Streets. I figure that run would be in the neighborhood of 500/530. I have been trying to get to the track and get new times, the last 2 times I have gone it's either been rained out or something's wrong at the track!! My car's a pig too, 3800lbs with me in it. I have done no weight savings measures whatsoever yet.
- Dug
Get'em to the track.
Well once the
ice melts.Great numbers by all though.
Rob, I will be getting in touch with you soon about one of those alky inj. kits. I want to see how much one of these stock shortblocks can take.
600.1 rwhp, 636.4 rwtq on a dynojet.
Everything is stock in the motor, EVEN the springs, no alcohol injection
This was showing 11lbs of boost on the dynojet.
Come spring, i will put it on the dynojet at the 13-14lbs we have had it at on the street.
I wish i knew how to post my dyno curves, but i did it at a dyno day, so there are a bunch of witnesses
Stenod
now if he made the gains you did when switching springs.
one thing amazing about his dyno is his torque it is almost a flat line of 600rwt across the board.
black02ss if you can email me your dynosheet (mustang or dynojet) ill host it and put it up for you. jharder@norcold.com
I also have only dynoed on 91 octane so far . . . have not tried any race gas at all. So while I had alky, no race fuel . . . I'm sure you top dawgs dynoed with some, right??
I had race gas in the car, but i consider that pump gas too, **** i pull up to the gas pump and pump it in just like everyone else. with the good race gas, i don't even bother with the 11lbs, car runs better at 13
I read the title as 100% stock LS1. Well, Comp 918 springs are not stock!
Pretty sick the stock motors are handling the amount of abuse some of us crazy ***'s are throwing at them, the question is how long, and how far can we continue to push them.
Stenod
