Highest RWHP w/Stock Engine and Boost?
So on this one I would have to go with Stenod in the #1 slot and Rob #2
Either way both insane #'s Great job guys!!! Makes me feel like my motor has a chance of staying together when I throw 10-12lbs of boost at it here in a few weeks.
It's got 67K on the clock and I want 100K+ before being forced to rebuild. Fingers and Toes are crossed
I agree, technically 918's take ya out of the 100% category . . . the guy who helps me tune my car really doesn't feel safe trying to take my car another pound . . . I'm getting too much valve float, aren't you getting any? How many miles on your engine?
And Rob, I assume you picked up TQ under the curve though, right? Just not peak? I know I've already past peak TQ by the time the valves float, but it dips hard at the top right with the HP on my dyno sheet, I figure I should get more TQ under the curve.
- Dug
If he had simply replaced the aging stockers with another stock set that would have been OK, and the 918s don't do anything the stockers don't in his stock cam application, so what's the matter?
If the timing chain breaks and he replaces it with a SLP heavy duty chain should that disqualify from stock engine? I wouldn't think so.
I got a spare set of 918's Joe can have, wanna see what happens
Stenod
p.s. I don't need 918's, we should just make a pull at the 13-13.5 we were going to run the day i **** my clutch. That would be interesting
. The Best V8 Stories One Small Block at Time
ok by the same math if your exhaust/intake pressure ratio is 1.69 then the boost affects the exhaust spring and the intake spring the same psi... anything higher and the exhaust spring is more important and lower the intake spring is more important.. on a 2.0/1.55 set up is that right?
As far as the cam goes, sure in an NA application. But the increase spring pressure sure does help when your pushing on the back side of the valve. Simple physics and you have a rough guess of the force you're losing.
Should give you a close approximation of the force applied to the valve in the opposite direction of the spring. You're not accounting for the stem area, or the fact the manifold side if the valve is not a flat disc.
What happens during an opening or closing event, i dunno. I'm sure there is some compressible flow experiment waiting to happen with this, but I'm an EE. Not my game
I'd be willing to wager it's having a negative impact on the spring pressure seen by the valve, to what extent it's hard to say.
Thanks guys.
