PT88 Rebuild
Old Apr 21, 2010 | 05:00 PM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Originally Posted by 98Z28CobraKiller
Not all of us have deep pockets. My 8.95 street car ain't too bad on a $7K budget (complete fuel system, shortblock, cam and ALL the turbo stuff). I'll concede that I could still use another $4K of supporting mods and maybe squeeze an 8.50 out of her but I'd rather get back up and running quickly and then build on it along the way. I doubt that it would be faster if everything were the same and put together by a shop. It might look prettier but it wont run harder.
Jamie (V-series) already got one for his set up, if it ever gets back on the road I'm sure you can check it out and see how annoying it is....
Do you know anyone with an STS kit? They come with return oil pumps, dont they?
Old Apr 21, 2010 | 10:34 PM
98Z28CobraKiller's Avatar
Restricted User
Originally Posted by MIGHTYMOUSE
yes picks up crank case from driver valvecover through pcv valve in valvecover, then through a 1 way boost valve, then through a catch can then on to the intake via brake booster T
i have a fresh air source to ls6 valley cover via filtered turbo inlet pipe air.
if you dont have a vent and the engine is fairly tight, it will draw too much vacuum on the crankcase.. adding the fresh air fent gives it some, but not too much to allow the turbo to smoke.
Thanks man. Sounds like a good option.
I believe that all rear mounts have to run them. Unfortunately, no locals currently are running rear mounts for me to check out.
If anyone has one that could chime in, can you hear it over your external fuel pump?
Old Apr 21, 2010 | 10:49 PM
mike13's Avatar
It depends which pump, the stock sts pump I couldn't hear but the mocal growls.
Old Apr 21, 2010 | 10:57 PM
Restricted User
Growl is an interesting way to describe it. I'm imagining a lower pitched fuel pump.
Old Apr 21, 2010 | 11:02 PM
mike13's Avatar
It's a growl, more industrial sounding than hi tech.
Old Apr 21, 2010 | 11:05 PM
RS_SS69's Avatar
No the STS ones are really not that loud at all, it basically is a low whirring sound. Kinda hard to describe but we have about 6 here locally and they all have a very tame and quiet sound to them. If you got it you would be hard pressed to hear it over your motor or exhaust. You would only hear it with the car off.
I think it would work good for you on a short run, they are hard to come by and STS doesnt like selling them seperate if you dont have a kit through them, If you want one shoot me a pm as I deal with a dealer and we can get parts seperatly.
Old Apr 21, 2010 | 11:12 PM
Restricted User
How much are they, ballpark? The Mocals are like 3 bills, right? Are the STS pumps reliable? What happens when these pumps fail? What I mean is, can the oil get around them if you have some drop in the line or does it just back up?
Old Apr 21, 2010 | 11:19 PM
RS_SS69's Avatar
I have to say they do just back up, if its not running then it has no flow. Thats why they recommend you run it key on engine off for a min to run the excess oil out. Honestly if you can get the other for $300 I would go for it as STS is around that price, I will try to get a solid price tomorrow.
Old Apr 22, 2010 | 12:00 AM
mike13's Avatar
http://www.racerpartswholesale.com/p...al_Cooler_Pump $179
Do a search on this forum and you'll find there are a lot of options for pumps.
Old Apr 22, 2010 | 07:36 AM
Tzion_ben_Arthur's Avatar
I use the turboerx pump. They have two pumps to choose from. The base md for about 250.00 and the bad boy fot 100.00 more. The best thing about these pumps is that they create a considerable amount of vacuum on the turb drain. They can also be mounted above the turbo and they can be ran dry without damage. They nowhere as noisy as my aeromotiv fuel pump.
Old Apr 22, 2010 | 06:56 PM
Restricted User
I took the rest of it apart today. No big deal really. The kit that I got included all new internal bolts with sealant, snap rings, spacers, bearings and a couple of other small components. Basically ALL the small stuff. The only pain in the *** was getting the snap rings out that hold in the bearing on the exhaust side as everything has to be done from the compressor side of the cartridge on these PT88's. I did have to order a new heatshield (I guess it's called) that goes behind the turbine wheel. The center was getting chewed up from age. The inside of the turbo was stamped 01/14/04 PT88 so it's an old fella. The piece set me back $50 plus the ride. Once I get it, I'll bring the finished assembly over to the guy I met yesterday so that he can rebalance it just incase.
Old Apr 29, 2010 | 05:49 PM
  #32
Restricted User
Turbo's fixed. No more smoke out the down pipe. Just got it done and took her out for a beat run. Got her up to 200* ECT and was doing some 12 psi blasts and going hard on the brakes right after to a dead stop. This would always make it smoke. The only thing that I haven't tried yet is a warm start. That's the other way that it would smoke.
I initially bought a rebuild kit for $95 that included all the internal stuff (snap rings, spacers, bearings, oil seals, internal bolts with sealant, and a couple of the small hard parts that I don't know the name). Once I got it apart, I found that I needed to replace the heat shield cap thing that goes between the center cartridge and the turbine wheel. That was another $50. Made sure to line up everything good on the marks and that was it. Pretty simple really.
Old Apr 29, 2010 | 06:23 PM
  #33
mike13's Avatar
did you have it balanced? Glad to here it worked, I don't have that kind of luck, I would have fired it and spit the compressor thru the hood.
Old Apr 29, 2010 | 06:24 PM
  #34
eviltwin_1987's Avatar
just lined the lines back up, no rebalance needed. right?
Old Apr 29, 2010 | 06:34 PM
  #35
Restricted User
Because I did not replace the compressor wheel or the turbine shaft, I just had to make sure that the nut, the shaft and the compressor wheel all lined up the same as they were. It is my understanding that they have to be balanced outside of the turbo, marked, taken apart and reassembled to the marks anyway. I called a local guy that rebuilds lots of marine turbos and he explained the process to me. He said I should be fine and that if I wasn't fine, "it would probably come apart fairly quickly so you will know."
Old Apr 29, 2010 | 10:41 PM
  #36
mike13's Avatar
I'm glad it worked for you, years ago I had a ballbearing turbo, pulled the turbine wheel off, slide the shaft out and all the bearing fell into the oil drain. $400 mistake. Limit Engineering was the only company rebuilding ballbearing turbos at the time or else I would of had a nice paper weight.
Old May 1, 2010 | 12:04 PM
  #37
Restricted User
Went to the track last night and made 3 passes at 16 psi.
1st Pass
9.44 @ 143.50 w/ 1.39 60'
Shortened the ramp on the boost controller from .4 to .3 seconds.
2nd Pass
9.357 @ 144.98 w/ 1.337 60'
3rd Pass
9.356 @ 145.01 w/ 1.336 60'
Pretty consistant.
Old May 1, 2010 | 12:25 PM
  #38
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Awesome, what gas are you using for 16 psi?
What are your cruising coolant temps like?
Old May 1, 2010 | 01:36 PM
  #39
Restricted User
I was using a C12/93 blend at about 50/50. The track used to sell the C16 by the gallon but apparently they stopped. Initially I just wanted to mix in 2 gallons of C16 and run about 12 psi (just for safety) but I ended up having to buy a 5 gallon bucket. Didn't want to pay almost $90 for the C16 so I bought C12 instead and turned it up a little higher to take advantage.
Car runs at about 200* at full operating temp cruising at 65 mph.
Old May 1, 2010 | 01:51 PM
  #40
MUSTANGBRKR02's Avatar
Good job. I bet you are glad you did it yourself. I try to do as much as i can myself to keep cost down, plus you get the expierence of doing it.
