limits on boost with ls1 edit
I just was thinking these are 2 bar map,and yes you can adjust
calc. airflow in edit but when does it become unreliable for boost,
above 15,20,25 PSI?
I will be dropping my compression very low 7.0 to 8.0-1 somewhere in this neighborhood to run higher boost on pump gas is why I inquire on this
is it better to put the MAF on the upstream
of the compressor or downstream, because flow
readings will be different.
which will give you a more wider range to work with?
i had an ls6 maf that topped off at like 350g/s and switched back to the stock meter because the ls6 maxed the Hz at about 3000rpm
I live in hampton va. mail me your file if you can to cstead@***.net
I'd rather see folks use the best MAF they can, as long as the price is reasonable. Scott was saying like ~$400 for one of their LS1 FI MAF's.
.. also that tune was used to a maximum of 11,800hz or so.. a t-88 can most certainly move more air than that.
