Boost with higher compression
Old Jan 7, 2004 | 04:48 PM
Kevyn's Avatar
Default Boost with higher compression
I have a 98 SS with PP stage II 5.3 heads,TSP 231/237 cam and most bolt-ons. I went this route because I never figured I would run FI.
My brother-in-law has a powerdyne blower that used to be on my car (I bought it from him). It has been collecting dust for going on 2 years now. I could pick it up pretty cheap.
Could I get away with running 4.5-6 lbs of non-intercooled boost with my setup?
Old Jan 7, 2004 | 05:26 PM
MIGHTYMOUSE's Avatar
with race gas, for sure.
Old Jan 7, 2004 | 06:11 PM
Kevyn's Avatar
I drive the car too much to use race gas all the time.
I guess I'll stick with my original plan of more cubes. It's just tough to see the blower sitting there without thinking about putting it to use
Old Jan 7, 2004 | 06:32 PM
put er up for sale along with the heads and save up for a big boy FI kit
Old Jan 8, 2004 | 12:06 AM
BIGBOS's Avatar
Don't mess with high compression and boost, on 93 with 10.6:1 comp and 6psi I blew the head gasket on #7
Old Jan 8, 2004 | 10:14 PM
DETROIT_AREA_00_SS's Avatar
Sell that Powerdyne FO SHO !
Old Jan 9, 2004 | 12:55 AM
Whistler's Avatar
Sawzall and Welder Mod
You probably wouldn't gain much over what you have now... that Powerdyne head unit doesn't flow enough air to support high HP.
Old Jan 9, 2004 | 07:17 PM
LINGENFELTER SS's Avatar
Im sitting at a 11:1 compression on my LPE heads and cam motor.
Running 4 psi of boost at this time. Not going to go more till the bottom half is done. Good Luck !
Old Apr 19, 2004 | 04:20 PM
Ed Blown Vert's Avatar
How much RWHP did you put out?
Old Apr 19, 2004 | 05:31 PM
510 rwhp on 4 lbs of boost
Old Apr 19, 2004 | 07:46 PM
slyws6's Avatar
on 93 octane? have you noticed any pinging or getting any KR?
-Sly
Old Apr 19, 2004 | 09:50 PM
-Sly
Nope none of that. The guys at Speed inc. gave it a conservative tune.
Also told me I shouldnt go over 5 psi. So I keep it at 4 lbs .
Old Apr 19, 2004 | 10:31 PM
I would like a bit more info on your set-up.
Old Apr 20, 2004 | 01:19 AM
Ok, LPE Top end kit(heads and cam). Procharger D1SC, 42lbs inj. ,Fuel pump. Anything else. I sold the D1SC Procharger and fuel system by the way. Going Turbo route from QMP. The procharger was very good to me, and it will be missed. .
Old Apr 20, 2004 | 06:26 AM
slyws6's Avatar
Lingenfelter SS: What size combustion chambers are on those heads? Are you running the factory short block? Also do you know how much total timing your running? Reason I ask is that I have the PP Stage III LS6 heads with the 59cc chambers and am looking to build a turbo kit here shortly, I'll be taking the heads off to have the combustion chambers opened up but want to wait until I get the kit on and ensure everytthing works right. Thanks...
-Sly
Old Apr 20, 2004 | 10:27 AM
Yes what was your timing and A/F?
Old Apr 20, 2004 | 02:13 PM
Combustion chambers on my heads I would have call LPE (I forgot what they told me). AF my average was 12.5. Timing Jim at Speed inc. did the tuning.
But I could ask.
Old Apr 20, 2004 | 03:24 PM
1point3liter's Avatar
But I could ask.
12.5 isn't exactly conservative.
Old Apr 20, 2004 | 03:48 PM
Well its not crazy either. I got that one of my dyno sheets at FinishLine Performance.
Old Apr 21, 2004 | 01:56 AM
Spinmonster's Avatar
With the overlap of that cam (231/237) there would be so much CR bleeding off that it will run fine on 93. Definitely run MLS gakets. The dynamic CR of that set-up is near 9.7:1 which would work up to 9psi. The off-boost performance wont be the best if you lower static CR. If you go with a smaller cam then you can't run the current compression.
