LQ4 Build
Yes I would like pics can u send them to batman4140@yahoo.com
That's incorrect. On a supercharged application with a free flowing exhaust, the cam shouldn't look too different from an NA cam as supercharged cars can take full advantage of exhaust scavenging unlike turbo applications in which case lower overlap is GENERALLY recommended as the high exhaust pressures can backup and contaminate the charge.
Well i finally talked to callies rods and they told me there "H" beams are only good up to 600-650. So for and extra 150-200 bucks i chose the "I" beams, they said they are good up to 1100. just thought i would up date you guys. Thanks again for the pics 1 bad94
i'm doin a similar build but i'm puttin a twin screw supercharger on top. there are 2 things i'd change in your build though, the stock crank (from what i've been told by a very good engine builder in Nor Cal) the stock crank is good up to 1000hp BUT not under constant pressures and heat from a supercharger application (probably not wording it right) it'll do it with nirtous cause nitrous doesn't put on strain the whole entire time you drive. and beings that i'm thinking about running the same boost as you i'd ask your engine builder about this. also i was told to stay away from the LS7 lifters at the power level i'm lookin at, but for the life of me i can't remember why he said to stay away from them
. anyway thats my input good luck on your build!!!
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
LQ4 366ci
Forged Pistons - Diamond 9.5-1
Forged Rods-callies "H" beam
Stock Crank
Ported 317's
*EPP blower cam
*Patriot 8401 Gold Springs
*Comp 7955 Push Rods
1.7 or 1.8 solid rockers
LS7 lifters
Katech C5R Timing chain
All ARP hardware
Clevite Bearings
Ported LS6 oil pump
Another Walbro 255
D1SC @ 12-15 psi (maybe more)
* Comes as a kit from EPP
If anyone sees a "weak-link" please speak up. Still looking into head gaskets (LS9 or Cometic) Hoping to make in the area of 650-750 HP
Stock Crank
Ported 317's
*EPP blower cam
LS7 lifters
All ARP hardware
Clevite Bearings
Ported LS6 oil pump
Another Walbro 255
stroking it is fun lol how much more did they quote for a forged 4" crank? that'd put you at 402CI
i'm goin through HKE for mine (iron forged 408) and i'm guessin it'll be about 5k for the engine since i'm goin to ask them for new pushrods, lifters and rockers and i'll ship them my heads and cam and have them put it all together then ship it assembled
Cost for the crank was another 600-800 bucks. Im trying to save as much as possible so im doing everything, porting to assembley. Good luck with your build, post your link so i can follow along
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
#32
So its been a year since iv done anything to the motor, cant build a motor on unemployment, lol. Since then found a great jod and was able to get the ball rollin again. There is only one change...no procharger(yet) staying the the bottle, and i still dont know what im going to do about lifters. If anyone could help out on that it would be great. Iv prob forgot to list some things too.
408 rotating assem. from TSP ( thanks jon)
Callies 4in stroke crank
Callies rods
Wisco ~ -20cc pistons
Epp blower cam/push rods/springs (thanks bob)
Stock 317's, ported
Ported ls6 oil pump
Harland 1.7 roller rockers
Clevite bearings
All arp hardwhere
Callies rods
Stock 317's, ported
Ported ls6 oil pump
Clevite bearings
All arp hardwhere
#33
