lq9 / lq4 ?
Old Jan 8, 2004 | 12:37 PM
MYTURBOT/A's Avatar
Default lq9 / lq4 ?
Has anyone came up with a stock for stock perfomance differance on a FI setup between the lq9 and lq4 6.0 heads?
Old Jan 8, 2004 | 02:38 PM
smokinHawk's Avatar
I thought they were the same.
no one has shown any diffence between them, except one costs more.
Old Jan 8, 2004 | 02:44 PM
y2khawk's Avatar
um, all the 6.0 heads are the same. Well, there are a couple different versions based on the casting process.
The CR difference between the 2 motors is the difference, not the heads. LQ9 = flat top pistons, LQ4 = dished pistons.
Old Jan 8, 2004 | 03:35 PM
10thanvhawk's Avatar
Angry
NOT AGAIN...
we need a charley brown ARRRRGGH smiley emoticon.....
Old Jan 8, 2004 | 03:36 PM
y2khawk's Avatar
not again what?
Old Jan 8, 2004 | 04:20 PM
Post
Originally Posted by y2khawk
not again what?
the repeated question of Lq4 vs LQ9
the question of differences and power etc.
I will admit it is asked more over on LS1.com
Old Jan 8, 2004 | 07:07 PM
MYTURBOT/A's Avatar
It`s asked so much because nobody so far has been able to answer it. Two sets of heads two differant part #s . Some say there is no differance but they can`t tell us why GM used two differant part #s for the same heads. Some say the lq9 heads are better but know one has flow numbers or proof. just wondering if somone had flowed them and put this debate to rest. Sorry.
Old Jan 8, 2004 | 07:46 PM
y2khawk's Avatar
part numbers are different because the base casting is different, the machining process is the same.
It's not a lq4/lq9 thing, is a supplier thing.
Old Jan 8, 2004 | 08:12 PM
MYTURBOT/A's Avatar
OK now i understand whats going on, thanks. If you don`t mind me asking I read in one of your other posts that you arent using your O2 sensors. i would like to do this also what Do i need to do to run that way and how would i go about tuning this way?
Old Jan 8, 2004 | 08:15 PM
y2khawk's Avatar
You basicically set the Temp to enable closed loop to the max value it will take. Then turn off all the 02 sensor codes.
You'll have to dial in your IFR and MAF with a WB O2 after turning them off, or dial them in based off L-trims before you pull the sensors.
If you're not gonna run leaded fuel, stick with them. No reason not to in that case.
Old Jan 8, 2004 | 08:57 PM
MIGHTYMOUSE's Avatar
wonder which one came from the plant putting out the ls6 block.. they had the denser aluminum or somethin to that affect.. was that the mexico one? sonic test!
Old Jan 9, 2004 | 08:51 AM
White_Hawk's Avatar
I think they come from Saginaw, but don't know for sure.
-Geoff
