budget twin build plan, input welcome
turbos: modular turbo twin kit IF THEY EVER RELEASE IT!!!!! with ball bearing TC76's
motor: forged 347 short block (see question below), PRC stage 2.5 ls6 heads, ported ls2 intake, holley 90mm tb, VA speed turbo cam (see question below).
questions below:
1. should i go with diamond or wiesco pistons? i hear that diamonds may be quieter (this is going to be a street car) but the wiescos are made and finished better? i'll probably end up going with eagle or scat rods.
2. are these the right size turbos for my application (street car and road racing)? or should i go with 67's or maybe 78's??
3. do you think the VTC-1 or VTC-2 would be a better cam for me?
4. what do you think the max power i can make out of this setups is? which component(s) is holding me back the most?
thanks in advance for any advice you can lend!!
staying 347 limits me to a max of around 700rwtq which will let me keep my current tick stage 2 t56 and monster 3 and 12-bolt
as for the turbos i'm now thinking 60's btw
It should make decent power, what else does the shortblock consist of ??
What is your goal for the car?
goals for certain: ~700rwhp (up to 800 if i can get it), car must be DDable (hence the small motor, mild cam combo), maybe a trip or two to the track but mostly open track days and street driving (not a drag car).
