Another Ebay turbo project ! Need Help...
Old Apr 29, 2010 | 10:39 PM
fastsspr's Avatar
Lightbulb Another Ebay turbo project ! Need Help...
Hello , guy i just both an ebay turbo kit to install it on my z28.Ok the kit i both is a different one than all the ebay kits i saw here. I think i going to past true the process of install a new and diferent kit here. Let see how it works and what result i can get with it. I'm working on small budget for this project. Any help or opinions you guys can give me are welcome. I going to post pics of the kit.
Attached Thumbnails Another Ebay turbo project ! Need Help...-dsc_0577.jpg   Another Ebay turbo project ! Need Help...-dsc_0578.jpg
Old Apr 29, 2010 | 11:27 PM
Fondle's Avatar
the o2 are in weird spots, usually they are in the header
also, i dont see an o2 in the downpipe that will be needed for the wideband, so i would get one welded in before you put this kit on your car
Old Apr 30, 2010 | 12:25 AM
fastsspr's Avatar
also, i dont see an o2 in the downpipe that will be needed for the down pipe, so i would get one welded in before you put this kit on your car
Yes i noticed the same thing and the rigth manifold looks like be facing to the back i don't know why but it going to sacrifice more space in the engine comparment. I won a bid relly cheap so i can sacrifice to put some work on it.
What turbo you think i can use safe with a stock motor factory internals?
Old Apr 30, 2010 | 07:27 AM
NightHawk's Avatar
There are a couple guys running that kit...not as many as the PTK thought, it seems. Do a search for Phamspeed kit and you should come up with some good stuff.
Old Apr 30, 2010 | 07:47 AM
Fondle's Avatar
most use a 76mm
Old Apr 30, 2010 | 07:59 AM
505OUTLAWZWS6's Avatar
You got this kit for more than cheap. I was watching it tuesday but was in the ER and couldn't bid on it haha. Thats a hell of a deal sir.
Old Apr 30, 2010 | 10:13 AM
fastsspr's Avatar
Thanks so much man for giving me some ligth!!!
Old Apr 30, 2010 | 10:30 AM
fastsspr's Avatar
Yeah man i can't regret, i think cheapies kit ever fron that day they put a reserve price to those kit.
Old Apr 30, 2010 | 01:25 PM
XtremeDime's Avatar
Im running a masterpower t70 on it. The wastegate discharge tube wont line up at all so you can forget about recirculating it. Plan on buying solid motor mounts because you will melt the stocks or polys. My o2 on the passenger side needed placed elsewhere because the existing one hits the starter.
Old Apr 30, 2010 | 02:19 PM
eviltwin_1987's Avatar
I hope your mechanical skills are better than your english skills.
Old Apr 30, 2010 | 03:02 PM
Super Slow SS's Avatar
I have the actual Phamspeed kit that the kit you got was built from, check out my build thread in my sig, should provide you with some info. Don't forget power steering lines!
Old Apr 30, 2010 | 09:23 PM
fastsspr's Avatar
Smile
Thank you , it going to be very helpful...
Old May 1, 2010 | 05:03 AM
MUSTANGBRKR02's Avatar
Pretty sure he is from a different country. English might be his second language.
Look in the stickies for everything to do your power steering lines.
Old May 1, 2010 | 12:03 PM
XtremeDime's Avatar
Ya man chill, this is why people think Americans are such dicks. Hes from Puerto Rico(yes I know its a territory, but still)
Old May 1, 2010 | 01:13 PM
fastsspr's Avatar
Thanks man i'm learning has much i can of the details for the instalation i'm not worry about my mechanical skills i'm more than positive i can do it...
You think going to a manual rack and pinion worth it with a front mount turbo?
Old May 1, 2010 | 01:16 PM
fastsspr's Avatar
hello Xtremdime you have a post of yuor install i did a seach but coud't find that one in specific ! Thanks
Old May 1, 2010 | 01:18 PM
XtremeDime's Avatar
Here you go man:
https://ls1tech.com/forums/forced-in...-ebay-kit.html
Old May 1, 2010 | 01:53 PM
Originally Posted by XtremeDime
That is the PTK kit you have the Phamspeed kit.
Keep power steering. Custom lines are cheaper than a manual rack.
Old May 1, 2010 | 01:54 PM
Look at Super Slow SS's build that is your kit.
Old May 1, 2010 | 02:16 PM
XtremeDime's Avatar
Oh I see! The crossover pipe from the pass manifold goes under k member! Im thinking about running my DP this way so that gives me hope.
