Procharger Hat Problem Fixed
Old Jun 17, 2010 | 04:24 PM
  #61
wforty94's Avatar
maybe this will be a better choice?
http://intakehoses.com/Merchant2/mer...gory_Code=9DEH
Old Jun 17, 2010 | 04:42 PM
  #62
ss.slp.ls1's Avatar
^^^It just says rubber elbow, no way of really knowing how durable it is and if it won't collapse under boost.
Old Jun 17, 2010 | 06:03 PM
  #63
dschmittie1's Avatar
I am gonna say NO Your gonna need something that is 4-5 ply and you probably will not find that for under $70
Old Jun 17, 2010 | 06:53 PM
  #64
Aster's Avatar
Anything flexible will collapse, at best restricting airflow, at worst damaging the impeller. If you need something super tight that will fit your best bet would be to buy some hard foam, fiberglass, and a decent size food vacuum sealer.
Shape the foam block to fit the space, seal it, wrap it in fiberglass and use the vacuum sealer to set it and hold it nice and tight while it cures.
Old Jun 18, 2010 | 02:47 AM
  #65
WHPLASH's Avatar
Originally Posted by No Juice
i have this filter and am willing to sell it for $45 shipped. never been used.
I'm guessing it didn't work or fit?[/QUOTE]
Anyone have this on their setup with the twin intercoolers? Any pics? That would give you the best air flow, I would think.
Old Jul 15, 2010 | 05:06 PM
  #66
stngtamr29's Avatar
I don't know if this would work or not but when I use to run sprintcars we had the same problem with our bottom radiator hose calapsing so we would put a spring the same size of the Id of the hose and it solved the problem
