Head gaskets for boost and 4.030 bore?
My stock gaskets are MLS type. When I changed out my heads to TEA heads, I had to change the gasket material. TEA o-ringed heads have a .041" stainless wire embedded into the head around the combustion chamber. This why you need the graphite gasket. The wire will not press into a MLS type and seal properly.
Originally Posted by BenKey
If your heads have the embedded o-ring, like TEA offers on their heads, then your only option is graphite. Fel-pro should have what you need.
Thakns
Kyle
Originally Posted by Reckless
FelPro has the graphite style gaskets for both 3.905 bire and the larger 6.0L bore:
3.905 bore (graphite) - 9284PT
up to 4.040 bore (graphite) - 9199PT
big bore (MLS) up to 4.100 I am told - 1041
So this gasket you said (3.905 bore (graphite) - 9284PT) does have the O-ring wire in it that i am looking for?? Thanks
Kyle
Graphite gaskets and o-rings don't do much for you. Copper gaskets are meant to be used with o-rings, NOT graphite. SCE and Flatout Gaskets both make LS1 copper head gaskets in the bore size that you need. To do it right, the block gets o-ringed. The wire is used on the block, then the heads have a receiver groove machined in so that the copper gasket will compress up into the head, further sealing the cylinder. IMO, you are asking for trouble using a graphite gaket and o-ring.
[QUOTE=LOnSLO]Graphite gaskets and o-rings don't do much for you. Copper gaskets are meant to be used with o-rings, NOT graphite. SCE and Flatout Gaskets both make LS1 copper head gaskets in the bore size that you need. To do it right, the block gets o-ringed. The wire is used on the block, then the heads have a receiver groove machined in so that the copper gasket will compress up into the head, further sealing the cylinder. IMO, you are asking for trouble using a graphite gaket and o-ring.[/QUOTE
What does everyone else think??
Nothin in the works. I am building engines for friends and some others here and there. This setup will be a 408 with D1SC and a cog setup. Just want to make 15psi without issues and do it right the first time. I will likely o-ring the block, but am undecided on gaskets. May try for some copper ones.
