Modified G-trim progress->
Old Jan 12, 2004 | 11:06 AM
S_J_H's Avatar
Smile Modified G-trim progress->
Building up my 348 ci G-trim combo a bit.
I am looking to get as much out of this Head Unit as possible and felt the stock Vortech plumbing could be improved upon.
Hand built 2.5" outlet and 4" inlet finished with Thermo-Tec wrap.
8"/2.5" pulley combo.
Mondo Bypass and still need to build a new methanol system.
Goal is low 10's at 130+mph. It's a 98 TA A4
A few pics here-http://community.webshots.com/album/110809010gjMiQe
Old Jan 12, 2004 | 11:07 AM
Malicious's Avatar
Thats pretty
Old Jan 12, 2004 | 11:41 AM
CHRISPY's Avatar
Cool!!
Looking forward to hearing your results!
Old Jan 12, 2004 | 03:13 PM
11secLS1's Avatar
Where is the MAF sensor?
Old Jan 12, 2004 | 03:16 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Is that orange ducting pretty solid?
Old Jan 12, 2004 | 04:19 PM
Blackbird's Avatar
if it's the same stuff like I am using then yes it's pretty sturdy.
from a company called hi-tech hose.
they are on the web. lots of good stuff as far as hoses go.
Old Jan 12, 2004 | 05:47 PM
S_J_H's Avatar
11secLS1- If you look at the other pics,one of them shows the 85mm maf slip fits inside the big 4" aluminum elbow.
John, oh yeah, this is good hose-
High-temperature silicone-coated fiberglass hose has a smoother bore than neoprene-coated hose. Use it to convey hot air, dust, and fumes when temperatures exceed the normal limits of rubber. Ideal for glass manufacturing and arc lamp venting, engine-compartment air handling, and turbine-bleed air ducting. Hose is odorless and holds up well over extended use.
High-Temperature Silicone-Coated Fiberglass
• Construction: Orange-red, 2-ply fiberglass fabric with silicone coating
• Reinforcement: Spring-steel wire helix and a fiberglass cord bonded to cover
• Temperature Range:
-75° to +500° F
• Compressibility: 1.5 to 1 for hose with 3 1/2" and smaller IDs; 2 to 1 for 4" and larger IDs.
Sizes from 3/4" to 12"
Cost me 15$ per foot from Mcmaster.com It can also handle 16psi-18" vacuum. But it only has to flow air for me. Lot's of air!
Steve
