car acting weird on dyno!
The car was getting tuned today and so far it has only made 20 more hp than before on motor. when the car gets to 5k rpm it falls hard on its face. we think the plugs are shot from being so rich on the drive to his shop bc the map sensor was bad. Its also misfireing. Only made 5lb so far. and havent put any timing in yet.
changing the plugs in the morning then trying again.
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
So yeah it nees afr dialed in to around 11.5 or 11.8 you could start a bit richer.And you don't add timing to boosted engines you take it out. You could be slow from drowned plugs, super rich afr. You could have lots of knock retard if you are at stock timing.
Get these things figured it and would think you should be at least 500rwhp at even 5psi.
You need to run about a heat range colder plug like tr6 or tr6ix and gap them around.028/.030 should be fine.
I assume you are still running maf not trying to go right to speed density although speed density is not that hard to run.
i should have kept the fast 90 with it, i now have the ls6 on it.
my tr224 cam is hot helping any with 112 lsa. but going to get a smaller pulley and run 10lb.
