Problems with boost gauge HELP!
Old May 26, 2010 | 06:26 PM
1998TA__1991RS's Avatar
Default Problems with boost gauge HELP!
I can not get my boost gauge to work, its an autometer 3404. the gauge is plumbed into the back of my intake elbowwith a brass fitting. if i crank the car up i have vaccum on the hose going to the gauge at idle, and if i blow into the back of the gauge it reeds boost. i cant think of another reason it wouldnt be reading any ideas? heres the gauge i have:
Old May 26, 2010 | 06:31 PM
MadIceV8's Avatar
Customizing Director
Um... boosted cars pull vacuum at idle. It isn't until you are actually driving the car that you will see boost.
Old May 26, 2010 | 06:38 PM
XtremeDime's Avatar
Lol..
Old May 26, 2010 | 07:38 PM
im not that stupid, lol, im saying if it pulls vaccum at idle it should obvioussly read boost under a load, ive foot braked the car under load and put it on the trans brake and it still doesnt read when a load is applied, nor when im going down the track
Old May 26, 2010 | 08:00 PM
XtremeDime's Avatar
Is the hose getting kinked anywhere?
Old May 26, 2010 | 09:20 PM
black98ws6ta's Avatar
If you tighten down the compression fitting to much it can kink it closed?
Old May 26, 2010 | 11:10 PM
MadIceV8's Avatar
Did you hook it off of the vacuum hose that normally went to the air pump? As that hose has a little check valve in it that will prevent boost reading.
Old May 27, 2010 | 12:13 AM
no, i have a single plane intake with eldebrock elbow, the back has a 90* brass fitting in it to go to the gauge, i dont think the hose is getting kinked due to it having plenty of vaccum on it at idle. i have the FPR referenced on the other side of the elbow the same way and it reads boost fine.
Old May 27, 2010 | 01:21 AM
75tonyA's Avatar
Maybe you can disconnect the brass fitting at the manifold and carefully blow air into the line to test it with an air compressor blow tip. I'd shut off the compressor and let most of the air out first to make sure you don't put too much air into the guage.
If the turbo is making boost and the car pulls hard, isolate the guage and test it.
Old May 27, 2010 | 05:22 PM
98Camarod's Avatar
Is there a kink going through the firewall or once it gets into the cab?
Old May 27, 2010 | 08:37 PM
BADBOB's Avatar
is the turbo maybe too small to be able to feed the engine with boost and the gauge at the same time?
Old May 27, 2010 | 08:50 PM
NightHawk's Avatar
I'm having the exact same problem with an autometer Z series boost gauge...shows vaccuum readings but even when the car is clearly into boost it doesn't register. I have mine referenced to the intake mani behind the throttle body.
Old May 27, 2010 | 09:16 PM
lifeisgood's Avatar
what? lol
Old May 27, 2010 | 09:50 PM
BADBOB's Avatar
Originally Posted by lifeisgood
what? lol
see what happens is when the turbo is too small it can only feed the engine and isnt strong enough to push the boost through the small boost gauge line that far from the engine. Common issue for small turbo cars.
Old May 27, 2010 | 10:26 PM
OUTLAWZ RACING's Avatar
lmfao!!!!!
Old May 27, 2010 | 10:56 PM
Originally Posted by OUTLAWZ RACING
lmfao!!!!!
x2
Old May 27, 2010 | 11:38 PM
thanks rob, now finish my downpipe.....
back on topic...any other ideas
Old May 28, 2010 | 01:59 AM
98Camarod's Avatar
How much of the small tube are you actually using before you tee it down?
Old May 28, 2010 | 02:15 AM
Bird-Of-Prey's Avatar
Whoa! Alrighty then. I guess you do learn something new everyday .
Try referencing it before the TB and see what it reads. Curious myself. Boost leak possibly?
Old May 28, 2010 | 02:50 AM
XtremeDime's Avatar
Originally Posted by black98ws6ta
x2
x3, hahah
