2002 Camaro ss overheating
Old May 27, 2010 | 06:11 PM
TYM OUT's Avatar
Default 2002 Camaro ss overheating
I have a 2002 camaro with a procharger, and I'm only pushing about five pounds of boost. When I turn the air conditioning on the temperature goes past 210 and sits maybe around 250. With the air conditioning off it doesnt overheat at all. Is this caused by not having a big enough fan? And if caused by the fan what is the best aftermarket fan i can get?
Old May 27, 2010 | 06:33 PM
Sweet_SS's Avatar
You have to remember when you use the a/c it draws on the motor...creating heat and energy. Motor has to work harder to run the pump. I would say changing your thermostat...cooler setting example 150 degree from say 160 degree. If that doesn't work, well then I say the a/c has to go. Are you using a stock radiator? If so, what is its condition? Is still in good shape?
Old May 27, 2010 | 08:37 PM
TYM OUT's Avatar
The radiator is in good shape the car only has 32,000 miles on it. Would a bigger fan help cool the motor down?
Old May 27, 2010 | 09:10 PM
2002sscamaro's Avatar
you could just sell me the procharger
Old May 28, 2010 | 11:47 PM
Sweet_SS's Avatar
I ran a spal 11" pusher (900cfm) fan on my import. You could upgrade to a better fan all together. Maybe another fan will work too.
Old May 29, 2010 | 02:05 AM
sixvi6-camaro's Avatar
I believe the Procharger kit removes the stock dual fans and replaces it with a single fan. That is probably part of the problem there.
Old May 29, 2010 | 06:57 AM
davered00ss's Avatar
Moderator
FI section might be able to help better.
T-stat should not be an issue unless it is not working at all which does not seem to be the problem because it is only when the ac is on.
I would upgrade to a high flow water pump. Possible look at a better radiator than stock.
Old May 29, 2010 | 07:17 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Adding a Spal 9 inch fan such as what we did at the old shop on this T/A will help it out. http://www.exoticperformanceplus.com/hotCars.php?car=62 Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old May 29, 2010 | 11:42 AM
youngrigo's Avatar
I went with this 9in fan and also upgraded the stock fan the procharger supplies to the Spal extreme fan that pulls i beleive around 2500cfm compared to the 1500cfm the the stock procharger one pulls.
