Anyone using the TC78 with the 1.15 AR?
Old May 28, 2010 | 09:23 PM
Pimpium57's Avatar
Default Anyone using the TC78 with the 1.15 AR?
Trying to see if the 1.15ar will out perform the .96 on a ETP-headed 347ci on E85. Is the later spool worth the added top end? Is there a noticeable "*** dyno" feel between the two?
Old May 28, 2010 | 09:37 PM
elias_799's Avatar
personally i think the 1.15 a/r is too big for a 347, unless you rev it sky high
Old May 28, 2010 | 10:34 PM
black98ws6ta's Avatar
Yes it will be worth it, esp since you are using e85. The PTE 76-78 gts will make more power
Old May 28, 2010 | 11:02 PM
Mas280's Avatar
I am using the TC78 right now with 1.15AR, The turbo spools very fast. Ran a best of 10.0@148 on 8psi E85 LS3 engine
Old May 28, 2010 | 11:06 PM
In something lightweight? Thats a ton of mph for 8 psi.
Old May 28, 2010 | 11:20 PM
Mas280's Avatar
RX7
Car use to run 140MPH NA
Old May 29, 2010 | 09:53 AM
DrTurbo's Avatar
LS1TECH Sponsor
Yes you will pick up another 40-50hp with the swap to the 1.15A/R. Ask the guys from Baker Engineering, they did some back to back with the .96A/R and then swapped to a 1.15A/R unit.
Old May 29, 2010 | 11:36 AM
The Fugitive's Avatar
what would the spool difference between the two? All things being equal just a quick turbo a/r swap?
Old May 29, 2010 | 02:32 PM
mike13's Avatar
That's a tough question to answer it depends on how much backpressure your seeing with a .96a/r.
My TC76 W.96 a/r had so much backpressure the motor would fall on it's face at around 5000rpm, the car would start pulling hard and fall off about 5000rpm.
I ended up going to a larger freer breathing turbo with a 1.25a/r
Old May 29, 2010 | 10:38 PM
simple's Avatar
Care to elaborate on your combination a little more? Pipe sizing, CID, power, boost etc. etc.
Old May 29, 2010 | 11:38 PM
mike13's Avatar
383 (stroked ls1) ported heads, 224/230 cam, I think the motor breathed to well for the .96a/r
Old May 30, 2010 | 12:27 AM
dudeman's Avatar
i have an extra 1.15ar housing with a 3" outlet if you need one.
Old May 30, 2010 | 01:17 AM
Johnv's Avatar
I have a TC 78 & 383 also and found it fell on its face around 5000 rpm,
went to a 1.32 ar housing and its much better, spools just as fast and makes power all the way to the limiter.
Gonna try a race cover next.
Old May 30, 2010 | 10:15 AM
020NN20's Avatar
Sorry to hijack the thread, but have a question, I have a forged 383, Ported 317's, with a ported prof low intake im building, have a pt78 with a .96 exhaust. is that gonna hurt me, if so i'd rather change it before i finish mocking up the rest of the kit. Please lemme know, thanks
Old May 30, 2010 | 10:46 AM
mike13's Avatar
I'm not a turbo expert but I would say yes.
Old Aug 1, 2010 | 07:39 AM
020NN20's Avatar
i know this is an old thread, but it kinda applies to me, I have a 383 that im building, pt78 with a .96 housing, and reading this thread, im guessing i should change to a bigger exhaust housing? If so, (kinda new with turbos) Do I just have to change the housing or do I need a new turbine wheel as well? Any help would be appreciated. Thanks, Dennis
Old Aug 1, 2010 | 07:42 AM
JAX04's Avatar
housing
Old Aug 1, 2010 | 05:25 PM
toretto's Avatar
Originally Posted by JAX04
housing
too many people attribute 'small housing = faster spool'.
at the end of the day, if its the same turbo/wheel, tis going to spool just about the same.
You wont notice the difference in terms of spool.
Your going to let the engine breath better and it will make more power per lb of 'boost'.
Old Aug 1, 2010 | 05:27 PM
JAX04's Avatar
S
Yeah. Except I was answering the question about the wheel and housing. Good read though.
Old Aug 1, 2010 | 08:16 PM
020NN20's Avatar
Ok, Im guessing they are turbo specific? Any idea on price for just the housing or does anyone have one? Thanks again in advance
