Best Turbo for the money??
Old Jun 1, 2010 | 09:12 AM
skeeters65's Avatar
Tag
Good info here.
Old Jun 1, 2010 | 09:00 PM
elias_799's Avatar
Originally Posted by darkhorizon
There are not many holset turbos I would run on a LSx motor. The best bets are really too big frame wise to be useful. A good 600whp turbo would be a HX52, as it is a pretty good frame size but the exhaust housing is a bit small (great for street response though, it spools like a T3 honda turbo).
In the 600+ range, the SX400 turbos are not a bad deal, you can get them new with T4 housings for cheap enough.
just use two
Old Jun 1, 2010 | 09:53 PM
MillsMotorvation's Avatar
Thanks for all the reply's. How can you know what size Holset you got?
Old Jun 2, 2010 | 09:35 AM
DrTurbo's Avatar
LS1TECH Sponsor
Most holsets you will have to pull apart and measure the wheels. The frame sizes tell you very little. Holsets in a HX52 can come from 54mm up to 71mm. HUGE difference.
Old Jun 5, 2010 | 04:23 PM
I measured it, and it has 62mm wheel on the comp, and 66mm on the exht. It came off a big truck, and has a huge exh housing!
Old Jun 5, 2010 | 05:22 PM
lazylongboarder's Avatar
Holsets are fantastic for the money, rebuild kits are dirt cheap, and they're very tough turbo's.
Not to mention more efficient wheels than Garrets. 62 yr old company that nets 14+ Billion a year. It's a matter of budget and extensive research, just better funded than any other turbo company. The 52/55/60's work well. Really well. And since you can find these locally in any major city on the planet used for cheap, why the hell not. I'm going with twin hx35's.
Spool before 3k rpm when selected correctly and great power where you want it. I think the reason why they're not popular with the LS motors is the jap import guys use em...I don't want much in common with them either
Old Jun 5, 2010 | 09:51 PM
Where can you get them? I have one off a semi, im going to try it to see what it does?
Old Jun 7, 2010 | 03:13 PM
That's the thing about holset, They aren't an aftermarket company, so they don't advertise what each turbo's efficiency range is. Lot's of research is involved before trying "to see what it does". Accurate compressor maps are harder to come by since most of them are produced by a third entity. Like the Dr ordered, measure the wheels before you test it out.
Anything above the Hx50 I believe came on a some sort of heavy diesel. The good news is, is that the wheel designs are are so efficient, if you go slightly big, you'll pay only a small price in response. These are awesome turbos!
Old Jun 7, 2010 | 03:42 PM
transammiller's Avatar
Restricted User
i will post pics but a local guy in my neighborhood has a 1991 AWD Talon with a Holset turbo with VGT. VGT starts building boost at around 2900 and makes 44 lbs on his 2.4 4G63T motor. he only paid 180 bucks for it and got it rebuilt/coated for another 100. best turbo for the money other than Master Power
Old Jun 7, 2010 | 05:16 PM
There's plenty of reasons the largest transportation companies on the planet use them...To start they're more efficient than any other out there.
The HX40 has more output and spools quicker than a Garret GT3076r...with journal bearings. If you'd like the map, i've got one.
But of course, there are better blowers, but you won't find one for under $1200-$1500.
The LS community will join the Holset bandwagon sooner or later.
Old Jun 7, 2010 | 07:50 PM
Well i need some good news, i will see what it does. Thanks for all the info! I saw someone on here with pics of one that was huge they put on there car, it looks like mine!
Old Jun 9, 2010 | 02:33 PM
  #32
434strokergt45r's Avatar
Banned Scammer
tc 76 or gt45r
Old Oct 10, 2010 | 08:58 PM
  #33
Anyone ever buy MP turbo from Dynamic? I see they have the TC76MP for $750
Old Oct 10, 2010 | 10:11 PM
  #34
LS1NOVA's Avatar
Master Power GT45 here, making 600rwhp and so far 10.70's. Its only a 68.9mm!
Old Oct 10, 2010 | 10:32 PM
  #35
bad6as's Avatar
Hi all, Im at the point where im going to need to get a turbo. I don't want to pay alot for this budget build. Here's what im hoping to get out of the car. Low to mid 10s. I have a LQ4 stock, planning on doing the ZO6 cam& spring swap, and a meth kit. 3.08 gear, TH350. Used will be good if it's in good shape!
at aprox 3700lbs you need 700hp for low 10s. dont go over kill on the turbo. no way in hell you need a s400 series. s380 is T4 based and all you need. talk to forced inductions. deal with him. i have a T4 based turbo, so does 98cobrakiller. we both make more power then you will ever want.
Old Oct 10, 2010 | 11:39 PM
  #36
Dragframe's Avatar
Or you could just order it from Rob at Modular Turbo. Great guy.
Old Oct 11, 2010 | 11:48 AM
  #37
DrTurbo's Avatar
LS1TECH Sponsor
We definitely can help.
Old Oct 11, 2010 | 09:16 PM
  #38
ModularTurbo's Avatar
ditto
Old Oct 11, 2010 | 10:00 PM
  #39
bad6as's Avatar
mine ship yet?
Old Oct 12, 2010 | 03:50 AM
  #40
ttbestas's Avatar
just wondering if those holset turbos are so great why our vendors do not sell them. Or i miss something here? They can do holset hybrids to match lsx, show the results and have good profit...People even can save on expensive external wastegates.
