which budget heads would u use?
Old Jun 8, 2010 | 09:48 PM
02LS1ram's Avatar
Default which budget heads would u use?
which budget heads would u use n why? I'm almost done peiceing together my D1 kit n I wanna lower the compression a little bit too be safe w runing 8 lbs. I'm looking at a set of 317's n sending them out for good port n polish, but before I do that, I would like to see what others have say about it
Old Jun 8, 2010 | 10:07 PM
izzman55's Avatar
my buddy uses 6L truck heads and they work great for him. i plan on getting the same.
Old Jun 8, 2010 | 10:26 PM
SoccerStudd101's Avatar
thats what I went with, 317's ported and polished. Installing them right now. So no #'s yet.
Old Jun 8, 2010 | 10:34 PM
87silverbullet's Avatar
I vote 317 heads.
Old Jun 8, 2010 | 11:20 PM
fatmat80's Avatar
i used prc ls6 stage 2.5..
I will have dyno numbers this weekend..
Old Jun 9, 2010 | 12:03 AM
020NN20's Avatar
317's on my turbo build, but still building.....
Old Jun 9, 2010 | 06:19 AM
BigRich954RR's Avatar
IF you have the heads use the 317 if not look into the TFS as cast think there selling around 1600 if you look around
Old Jun 9, 2010 | 09:04 AM
02LS1ram's Avatar
It looks like 317's r the way to go, how thick of head gasket should I go with?
keep me posted when u get the #'s for using those heads. much boost u goin with?
Old Jun 9, 2010 | 09:10 AM
02LS1ram's Avatar
Thumbs down
I'm not sure on what type of compression I should be at w head gasket thickness, but if it helps I would like to be at or around 550rwhp
Old Jun 9, 2010 | 10:54 AM
Why lower compression for only 550 hp ?
Old Jun 9, 2010 | 11:26 AM
-Q-'s Avatar
-Q-
That's what I was thinking...8psi is safe with the stock heads. Do you plan on turning up the boost more in the future?
Old Jun 9, 2010 | 11:29 AM
jay_rich's Avatar
Im in the middle of my build.
317s, with PRC dual gold springs, light port work by myself, and gonna do a valve lap on them, then mill them the minimal for cleanup.
Also running a LS9 headgasket .053(iirc)
Jay
Old Jun 9, 2010 | 11:44 AM
02LS1ram's Avatar
I prob won't but I wasn't sure if it was a good idea to do since I'll have the heads off
Old Jun 9, 2010 | 11:48 AM
02LS1ram's Avatar
I'm not worried about what the heads can handle, I don't want the bottom end to blow apart
Old Jun 9, 2010 | 12:20 PM
-Q-'s Avatar
-Q-
I think your bottom end is pretty safe on 8psi. With a stock cam, its not like you can wind it to 6500+ rpms or anything. Just my opinion, though.
Old Jun 9, 2010 | 12:22 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
8 psi with stock compression should be just fine as long as you get a good tune. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jun 9, 2010 | 12:28 PM
youngrigo's Avatar
I wouldnt spend any money on heads if your only going to be making 8psi IMO
Old Jun 9, 2010 | 03:29 PM
Changing the heads wont make the bottome end stronger ?
If anything lower you compression will only make you low end power suckier when off boost
Old Jun 9, 2010 | 04:08 PM
02LS1ram's Avatar
[QUOTE=BigRich954RR;13445994]Changing the heads wont make the bottome end stronger ?
I know that. I think u misunderstund. I'll just stay w the stock compression
Old Jun 9, 2010 | 04:39 PM
-Q-'s Avatar
-Q-
If you can find a decent set of 243s, I'd swap to those if you have the funds and since you said you'd already have your stock heads off. That's my plan for this winter...blower cam, meth, and maybe some 243s if I can get a set for a decent price.
