Any decent hp non-intercooled guys???
Anyways, with the devils own on straight water I logged underhood ambient. Only one test pass. Then I drained the tan and put in 50 50. It dropped another 25 degree for a total of 100 degrees less then no water meth. On a car that is only at 117 now....thats about were I ve seen a coupe others cars I ve done. With water meth they get into the 60's.....about 30 under ambient.
All this depends on jet size, pump set up, pressure, on psi, full psi etc....only testing and logging to know for sure.
BTW idiots for banning e85....I cant believe it......good for everything and ban it...
It sounds so retarded I bet Las Vegas motor speed way will jump on board with that. On the plus side no one that works there is bright enough to be able to tell what e85 is...
Did then ban m100..........I d do that. Wait I all ready am..
Dynos usually show high IAT because even with a big-*** fan blowing straight into a car the airflow is not the same as driving. How are you IAT's on the street or strip?
Jim
Any way spray a 50 50 meth mix and u should pick up power aswell. I think straight meth helps more for a octain boost ie low combustion temps. Water is the best absober_spellin_ in heat transfer.
Thank you.
Nope. Not kit on the car this year. I have some idea's in mind. Just gotta get the time to try them out. I better hurry up because as soon as the boat hits the water, the car will be on the back burner.
