jgs wastegate and boost controler help
#41
I would run a single line from the top of the gate to the compressor housing. This should basically max out the turbo. Do a short pull/burst and see what the boost does. If it does not make alot of boost you have a cold side leak, or you are maxing out the turbo(s).
Situations like this is why I like the new PTE gates...they come with multiple springs...enough to hit each boost level from 1.5 to 25.5 in 1.5 lb increments.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
The new precision 46 we put on my buddies car was a nice gate, came with all the springs so you can run a lot of different boost levels like mention above. I'd go that route over a JGS if I ever bought another one, just replace the hardware as the bolts aren't very good imo. Other than that, great gates.
#43
Your lucky LOL I forgot to zip tie a hose going to my waste gate on my 87 GN some years ago and heard the dam head gasket go before i had a chance to let out of it. Worse part was,,, i was taling a little hotty for a ride to show her what a boosted car felt like LOL
