stock 06 gto A4 with F1 procharger 13-15psi
Old 07-31-2010, 07:31 PM
  #41
JAX04's Avatar
nice job man, can we see the graph??
Old 07-31-2010, 09:11 PM
  #42
imnmbr1's Avatar
so you are running a 4.25 pulley?
Old 08-01-2010, 01:57 AM
  #43
DevonsZ's Avatar
Yes he is. Along with a 10lbs wastegate.
Old 08-01-2010, 02:21 PM
  #44
kblehm's Avatar
Post your vids!!!!!!!!!!LOL!!!!! Had a blast at the dyno yesterday but it could have been better if it wasnt so damn HOT!!!!!!!!!!!
Old 08-01-2010, 05:50 PM
  #45
9sectruck's Avatar
im trying there is 800mb of video, its taking forever to down load
Old 08-01-2010, 10:29 PM
  #46
kblehm's Avatar
You need to empty that memory card once and awhile!!!!LOL!!!!
Old 08-01-2010, 11:09 PM
  #47
9sectruck's Avatar
here is the 501 dyno pull, forgot to upload the graph that will be tom. http://www.youtube.com/watch?v=Flmzqdhikas
very happy for a mustang dyno
Old 08-02-2010, 11:08 AM
  #48
LS1Silverado05's Avatar
Impressive!! Glad it went good for you!!
Old 08-03-2010, 04:34 PM
  #49
ColossalCamaro's Avatar
...4L65E not 4L60. Just saying...
Old 08-03-2010, 05:14 PM
  #50
JAX04's Avatar
true
Old 08-03-2010, 07:41 PM
  #51
9sectruck's Avatar
here is the graphs, the 511 tq was on a graph that I accidentally down shifted into second, this is the final pull final numbers
http://i788.photobucket.com/albums/y...nograph001.jpg
Old 08-04-2010, 09:32 AM
  #52
imnmbr1's Avatar
F1a? F1c?
Old 08-04-2010, 07:46 PM
  #53
9sectruck's Avatar
just straight f1 NOT the C,A, or R series, its the smallest f series out, I see a spike of 13psi on the street then the waste gate opens and holds a steady 11psi threw the gears, im hoping by next year I will be a forged, then the waste gate is coming off
Old 08-04-2010, 08:48 PM
  #54
JAX04's Avatar
Time to change sig
Old 08-04-2010, 09:25 PM
  #55
danbap's Avatar
can you explain your wastegate set up? is it just a normal turbo wastegate piped in the charge pipe?
Old 08-04-2010, 09:49 PM
  #56
9sectruck's Avatar
Originally Posted by JAX04
Time to change sig
lol, Been trying to change sig and adding the goat to the album but i keep getting Fn errors loading the pics, (congrats on fuel pumps)
Old 08-04-2010, 09:57 PM
  #57
9sectruck's Avatar
its just a cheap $60 38mm waste gate, with a 10psi spring, no vacum/boost lines hooked up like you normally would with a turbo set up, I just let the waste gate spring open when it wants, the waste gate dumps right before the maf, Im in SD mode, i only run the maf for the iat sensor, soon to be changed
Old 08-18-2010, 06:36 PM
  #58
9sectruck's Avatar
I plan on going to the track this friday, any guesses on the et/mph, 100% stock drive line, (A4) with a set of mt radials, I only turned the dyno to 6k, my shift points are set at 6200, since the dyno I have smoothed out the timing table witch bumped timing in the mid range around 5degs of timing from 3500-4800rpm total timing at 6k and up is still locked at 18degs, and i put a third kit of pure meth, so now I run two 14gal/hour and one 16gal/hour so a total of 44gal/hour meth at a time, it goes threw 14oz in every 1/4 pass, My meth kit is a AIS kit 250psi pump
Old 08-18-2010, 07:49 PM
  #59
JAX04's Avatar
im excited to see how you end up!!
Old 08-18-2010, 09:38 PM
  #60
9sectruck's Avatar
on the street I used the odometer to do a 1/4 pass sense are cars read in tenths, at xxxx.25 miles my speed was 126ish on the street/ street tires, the mid range is alot strong with the extra timing, if i was to get a decent 60 i should be knocking on 10s yes?
Quick Reply: stock 06 gto A4 with F1 procharger 13-15psi
