Turbo 400 users - Inside Please!
What rear-gear ratio and tire size are you using??
Also, please indicate if you still drive your car on the street/highway.
I'm changing my setup to a TH400 this season, would like some input.
Thanks.
For the street its an awesome tranny, especially with the manual valvebody, get a trans brake if you plan on racing it, that will help you a lot, trust me.......
My trap speed should be around 130MPH.
I have two gears at home, one is a 3.70 and the other is a 3.50, I think I am doing the 3.70 at this time.
The brake will allow you to launch off full boost and the optional 2.75 first will give you plenty out of the hole. I think a 3.42 combo with 28 inch DR's on the street and 26-27x10 inch slicks at the track would work very well and still allow you to get some semblance of gas mileage. I also think you wouldn't need to go quite as high on the stall as an NA car. Maybe 3000stall. Thw extra torque of the turbos really helps
Chris
