Installing 3 Bar map sensor on LS6 intake.
Old Jun 5, 2013 | 02:04 AM
Vetal's Avatar
Thanx MightyMouse. I'll look closer how can I seal my original MAP sensor in place, without removing LS6 intake. Will have to use mirrors probably
So RTV is fine in there? I was afraid it might get sucked in under heavy vacuum...
Old Jun 6, 2013 | 08:39 AM
skinnies's Avatar
You can tap the back of the intake it is plenty thick, we have done this on a lot of cars. Ideally you don't want the map sensor mounted upside down as it can get moisture to sit in it and cause issues.
Old Jan 5, 2014 | 07:09 PM
Patsy57's Avatar
if you dont want to tap the intake (FAST etc) can you T off the Break Booster line and get a good signal?
Old Mar 20, 2018 | 12:46 AM
dawgs74's Avatar
Originally Posted by MIGHTYMOUSE
flip that thing over you get condensation in that port on the sensor and your gonna get false readings
Old Mar 20, 2018 | 07:46 AM
MIGHTYMOUSE's Avatar
it was under the cowl and worked perfectly for 10 years.
Old Nov 5, 2020 | 05:42 AM
98SSHARDTOP's Avatar
Originally Posted by 99Ws6TransAm
Hmm ok. Theres a small vaccum line in the back of the intake. I blew it off last year in a run down the strip.
thats what keeps your ac blowing through your front vents and not just at your feet
