00 turbo ta...2bar 3bar??? Wtf
Ok so now I'm confused... I have a 2000 ta, WHAT maf sensor do I need? I'm planning on 12 to 14psi. I am completey lost! What bar does mine have stock?and what will I need? I have one from a turbo cobalt but heard it won't work??? Then I heard my computer wont read three bar?
I tryed searching...do they make one that I can simply plug in and not worry about? Btw Its a SD tune I wanna go with
I also don't want to be drilling a tapping anything
thanks
thanks
thanks
thanks
If your going SD tune and dont have a fitting in the compressor of your turbo for your wastegate ,just remove your (mass air flow) sensor completly,,,,,, and put in a delete pipe like i did and just tap or weld a fitting into it and you can use this for your waste gate or boost controler .On the other note,,, the Colbalt 2 bar is what im running also. Plug and play and works great IMO
