Starting 5.3 turbo E85 build?
Old Jun 24, 2010 | 05:02 PM
99tramsamc/fia's Avatar
Default Starting 5.3 turbo E85 build?
Wantted to start this project for a while, finally got some of the other stuff done.
I want to put a stock turboed 5.3l in and 95 camaro and run it on e-85.
Question is what turbo? t-70,t-76 or should i go with a garret 45 or something like that.
Anyone use the masterpower stuff, how dose it compare to a garret, turonetic? Dose it need to be a ball bearing turbo? not looking to max it out.
I would love to see it make 600 RWHP.
is that posible? use truck manifolds.
What size wastegate and BOV. 40mm?
I've heard that at 10-12 psi i dont need a intercooler?
how far can i go on e-85(its a 5.3).
I dont plan on driving this everyday,its just something else to spend money on.
Car is completely striped can i still use the stock k-member? or would it be easier to just buy a Bmr k-member. Anyone have pics of there set-up with a stock k-member(maybe from underneath).
I will fab my own crossover pipe, and exhaust.
Thanks guys should be fun
Old Jun 24, 2010 | 05:14 PM
71 chevy's Avatar
man, go with the t76
Old Jun 25, 2010 | 01:27 PM
I thought so. But, Who's?
What about wastegate and bov size?
Old Jun 25, 2010 | 03:12 PM
JAX04's Avatar
do you know what all is involved with swaping an LSx into a pre 98 car?
Old Jun 25, 2010 | 05:49 PM
its a drag car. built two allready.
Take a look at my car. I can do some fab work.LOL
Old Jun 25, 2010 | 06:39 PM
98Z28CobraKiller's Avatar
Restricted User
I think that he was talking about the wiring, gages and computer. If it's a racecar, no big deal. That's all extra weight.
Old Jun 25, 2010 | 10:15 PM
JAX04's Avatar
i was cobrakiller, lol.
Old Jun 28, 2010 | 05:26 PM
Anyone use e-85? What kind of boost/ hp?
Old Jun 28, 2010 | 06:18 PM
blazin's Avatar
on a twin 370 we made 650 hp on a mustang dyno on 12 psi and 19 degrees of timing. twin pumps and 80lb injectors are maxxed out we think.
Old Jun 30, 2010 | 12:09 PM
do you think it was the pump or the injectors?
Old Jun 30, 2010 | 10:03 PM
nastychevelle's Avatar
go 72+ on turbo sizing
it will make 600 easy
use truck manifolds flipped
38mm+ on wastegate and it doesnt matter on BOV
use a intercooler CX racing on ebay run $120ish
80# injectors twin 255's in the tank
buy a LS1 k member
buy a harness from speartech or have them modify yours
Old Jul 5, 2010 | 12:34 PM
Going to run fuel cell instead of tank. Have a aeromotive a1000 is this big enough?
Need to get a controller/booster.
For $120ish i will for sure run some kind of intercooler.
Old Jul 5, 2010 | 05:13 PM
JASON 77's Avatar
truck manifold setup will be enough, since u do not require a/c. there r lot of people run the economy Master Power turbo's power level you r asking for can b achieved with a MP T70, or just do the MP T76.
as for intercoolers this is what i think i used on mine
http://cgi.ebay.com/ebaymotors/32x12...Q5fAccessories
Old Jul 5, 2010 | 05:51 PM
Restricted User
Still looking for the ceiling on E85. THe **** is awesome. LS2Formula's car is twin tc78's on a 422ci motor. So far 7.9 @ over 180 mph.
Old Jul 5, 2010 | 09:59 PM
a1000 will be fine
get a a1000 regulator too
